×Hello,
I've tried to ask this once before, only it got marked as SPAM? After this ive posted it @ trello and now im asking it here :)
When i try to import trello cards with the JIRA importer (JIRA 7.5.3) i'm getting this error:
An error occurred whilst rendering this message. Please contact the administrators, and inform them of this bug. Details: ------- org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getFormTitle' in class com.atlassian.jira.plugins.importer.web.ImporterLogsPage threw exception com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:Status][sequence,99][statuscategory,1][name,Requirements freeze WS1 20-2-17 release 15-5-2017 in productie][iconurl,/images/icons/statuses/generic.png][description,][id,10731] (SQL Exception while executing the following:INSERT INTO dbo.issuestatus (ID, SEQUENCE, pname, DESCRIPTION, ICONURL, STATUSCATEGORY) VALUES (?, ?, ?, ?, ?, ?) (String or binary data would be truncated.)) at
Servers:
Windows Server 2012R2
SQL server 2014
Hi Nick,
When you asked on the Trello side did you get a response? Usually when I see this in JIRA it's related to the collation as outlined in SQL Exception while updating issues or importing data in JIRA applications with MySQL due to encoding. You'll need to verify the encoding using the steps below:
Verify the System Encoding encoding is utf-8
in Administration > System Info > System Encoding. If it is not, add the below argument to the JVM, as in Setting Properties and Options on Startup.
-Dfile.encoding=utf-8
-Dsun.jnu.encoding=UTF-8
dbconfig.xml
, as in Connecting JIRA to MySQL.Verify the table collations are all utf8_bin
by executing the below SQL on the JIRA database:
SELECT DISTINCT C.collation_name, T.table_name
FROM information_schema.tables AS T,
information_schema.`collation_character_set_applicability` AS C
WHERE C.collation_name = T.table_collation
AND T.table_schema = DATABASE()
AND C.collation_name != 'utf8_bin';
And verify the database collation is utf8_bin
SELECT default_collation_name
FROM information_schema.schemata S
WHERE schema_name = (SELECT DATABASE()
FROM DUAL);
If the database is not utf8_bin
for both the tables and database, it will need to be recreated with the steps in SQL Exception while updating issues or importing data in JIRA applications with MySQL due to encoding.
Branden
Branden,
This is for MySQL, not MsSql (microsoft SQL server) am i correct?
