Error rendering 'com.atlassian.jira.jira-view-issue-plugin:attachmentmodule'.
Philippe Leménager
April 24, 2013
Hello
We have an issue with attached files and after selecting this issue, we have the error message given in the title of this question.
I googled it and I saw Jira Issue JRA-29357 that is Unresolved and Unassigned.
I've exported the files from data directory to my computer and I can already open the files.
The "thumbs" sub-directory is empty. I tried to erase it and renew the page then I got the same error message and the sub-directory is recreated and is empty again.
Does anyone have a solution ?
Henning Tietgens
April 24, 2013
You can use the manage attachments link to delete the attachments (after downloading, if you don't have them already).
After all attachments are removed the display should be back to normal. Now you can upload the attachments one by one to identify the attachment where the error occurs. Now you should rename this attachment, so that JIRA doesn't try to display it (something like .rename_me at the end should work).
Henning
Philippe Leménager
May 12, 2013
Thanks for your answer.
In fact, I tried to delete the uploads one by one and recharge the page after each delete and it works. I could preserve 12 files.
The strange thing is that the crashed files can be read on my computer. I've tried to upload them again and it failed.
I've noticed that the author of the issue have tried to upload the crashed files several times. Could it be the cause of the problem ?
Henning Tietgens
May 12, 2013
IMO the Java code used to display the attachment has a problem with the attachment. Details should be visible in the log file.
Philippe Leménager
May 12, 2013
I've found thi error in catalina.out :
2013-05-13 12:28:28,064 ajp-bio-8009-exec-1578 ERROR chuette 748x86063x1 1v32s19 90.7.222.63 /plugins/servlet/streams [atlassian.streams.api.StreamsEntry] An unknown error occurred while rendering a Streams entry
java.lang.IllegalArgumentException: Numbers of source Raster bands and source color space components do not match
at java.awt.image.ColorConvertOp.filter(Unknown Source)
at com.sun.imageio.plugins.jpeg.JPEGImageReader.acceptPixels(Unknown Source)
at com.sun.imageio.plugins.jpeg.JPEGImageReader.readImage(Native Method)
at com.sun.imageio.plugins.jpeg.JPEGImageReader.readInternal(Unknown Source)
at com.sun.imageio.plugins.jpeg.JPEGImageReader.read(Unknown Source)
It seems that it concerns JPEGImageReader but I don't understand what it means exactly.
Can it be caused by a bad JPEG format in entry ?
Henning Tietgens
May 12, 2013
Yes, seems to be a malformed jpeg file (or a bug in the jpeg reading method). In http://stackoverflow.com/questions/10416378/imageio-read-illegal-argument-exception-raster-bands-colour-space-components it's most of the time a greyscale jpeg with wrong color profile. But details are beyond my knowledge :-)
Philippe Leménager
May 12, 2013
OK thank you.
The author of the issue have uploaded her files in pdf and it works.
Problem solved for me.
Philippe Leménager
May 12, 2013
atlassian, jira product discovery, product operations, product ops, linkedin live, atlassian events, cross-functional collaboration, product management, engineering collaboration, design collaboration, atlassian learning, agile teams, product strategy
Product Ops Unpacked: 4️⃣ tips every product pro needs to know ✍️
Join PM Evangelist, Axel Sooriah, & Product Ops. Consultant & Advisor, Jenny Wanger, as they unpack the role of product ops and discuss key takeaways in Atlassian’s ‘The Product Ops Mission’ guide. They’ll answer your questions live on May 6 at 9:00am PT.
Register here ⬇️
