Error to import a project (Jira -> Jira) with custom field Sprint
Alice Arashiro
November 12, 2012
I'm facing a problem when I try to import a project from another Jira's instance. Both are running the same Jira version (5.1.1) and same GreenHopper version (6.0.7)
I will try to enumerate the steps:
1 - On origin instance, I go to Backup and save it.
2 - On destination instance, I go to "Import Project", I type the filename for the backup file created on step 1 (the file is already on appropriate location on linux file system) and I click "Next".
3 - I choose the project I want to import, and click "Next"
4 - At this point, the issue comes up. I got a green check for all System Fields, except for this one:
Custom Field Configuration
Unable to import custom field 'Sprint'. The custom field type does not support project imports.
I still can go on, click on "Import" and have my project properly imported. But all the informations about the Sprints appears empty on destination instance.
What should I do?
Thanks in advance
Alice
Zul NS _Atlassian_
November 12, 2012
Hi Alice,
There is an Improvement ticket being raised relating to this issue. Feel free to vote and watch the issue.
https://jira.atlassian.com/browse/JRA-28748
Alice Arashiro
November 28, 2012
Tks Zulfadli,
I will watch the ticket JRA-28748
