Error using IE Edge
Roberto Silvestri April 25, 2018
Using Jira Software 7.9.1 I have the following problem using IE Edge
Can you please help me ?
thanks...
Roberto
◦Exception: Azione non valida per l'oggetto
◦Resource: https://jira.seko.com/s/ef83f3796a4e42d15306dfa676550911-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/c0bc59d472a5b31075aaddcdc55297b4/_/download/contextbatch/js/greenhopper-rapid-non-gadget,atl.general,gh-rapid,jira.project.sidebar,com.atlassian.jira.projects.sidebar.init,jira.global,jira.general,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&is-server-instance=true&is-system-admin=true&jag=true&jaguser=true&jira-nps-enabled=true...
◦Line: 26513
◦Column: 2146
Environment
Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; .NET4.0E; Media Center PC 6.0; InfoPath.3; wbx 1.0.0; rv:11.0) like Gecko
Stack trace
•TypeError: Azione non valida per l'oggetto
• at AJS.parseUri (https://jira.seko.com/s/ef83f3796a4e42d15306dfa676550911-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/c0bc59d472a5b31075aaddcdc55297b4/_/download/contextbatch/js/greenhopper-rapid-non-gadget,atl.general,gh-rapid,jira.project.sidebar,com.atlassian.jira.projects.sidebar.init,jira.global,jira.general,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&is-server-instance=true&is-system-admin=true&jag=true&jaguser=true&jira-nps-enabled=true...)
• at e.getStateFromUri (https://jira.seko.com/s/ef83f3796a4e42d15306dfa676550911-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/c0bc59d472a5b31075aaddcdc55297b4/_/download/contextbatch/js/greenhopper-rapid-non-gadget,atl.general,gh-rapid,jira.project.sidebar,com.atlassian.jira.projects.sidebar.init,jira.global,jira.general,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&is-server-instance=true&is-system-admin=true&jag=true&jaguser=true&jira-nps-enabled=true...)
• at e.toViewState (https://jira.seko.com/s/ef83f3796a4e42d15306dfa676550911-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/c0bc59d472a5b31075aaddcdc55297b4/_/download/contextbatch/js/greenhopper-rapid-non-gadget,atl.general,gh-rapid,jira.project.sidebar,com.atlassian.jira.projects.sidebar.init,jira.global,jira.general,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&is-server-instance=true&is-system-admin=true&jag=true&jaguser=true&jira-nps-enabled=true...)
• at r.getCurrentUrlState (https://jira.seko.com/s/ef83f3796a4e42d15306dfa676550911-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/c0bc59d472a5b31075aaddcdc55297b4/_/download/contextbatch/js/greenhopper-rapid-non-gadget,atl.general,gh-rapid,jira.project.sidebar,com.atlassian.jira.projects.sidebar.init,jira.global,jira.general,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&is-server-instance=true&is-system-admin=true&jag=true&jaguser=true&jira-nps-enabled=true...)
• at u.init (https://jira.seko.com/s/ef83f3796a4e42d15306dfa676550911-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/c0bc59d472a5b31075aaddcdc55297b4/_/download/contextbatch/js/greenhopper-rapid-non-gadget,atl.general,gh-rapid,jira.project.sidebar,com.atlassian.jira.projects.sidebar.init,jira.global,jira.general,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&is-server-instance=true&is-system-admin=true&jag=true&jaguser=true&jira-nps-enabled=true...)
• at j (https://jira.seko.com/s/a32e287238873de63e3e6ef5f92eca5b-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/ec4c7026e785f91221e62339fae9bf24/_/download/contextbatch/js/_super/batch.js?locale=en-US:66:50)
• at n.fireWith (https://jira.seko.com/s/a32e287238873de63e3e6ef5f92eca5b-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/ec4c7026e785f91221e62339fae9bf24/_/download/contextbatch/js/_super/batch.js?locale=en-US:67:361)
• at ready (https://jira.seko.com/s/a32e287238873de63e3e6ef5f92eca5b-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/ec4c7026e785f91221e62339fae9bf24/_/download/contextbatch/js/_super/batch.js?locale=en-US:55:418)
• at Q (https://jira.seko.com/s/a32e287238873de63e3e6ef5f92eca5b-CDN/-fm83gl/79001/b6b48b2829824b869586ac216d119363/ec4c7026e785f91221e62339fae9bf24/_/download/contextbatch/js/_super/batch.js?locale=en-US:65:10)
SMS
May 1, 2018
Roberto,
Thank you for confirming.
This is due to a recent bug in Jira Software:
The workaround is to use a different browser in the meantime. I would recommend that you vote on the bug in order to help show the number of users who have run into the problem, and watch it for updates!
Take care,
Shannon
iamz
May 2, 2018
thank you!
Roberto Silvestri May 1, 2018
HI,
really appreciated help...voted
many thanks
Roberto
Roberto Silvestri April 30, 2018
simply select "Boards" menu and select a board
The english language is already selected
Checking into the compatibility table (https://confluence.atlassian.com/adminjiraserver/supported-platforms-938846830.html )for Jira server 7.9 I can see that Microsoft Edge and IE 11 are supported.
thanks,
Roberto
SMS
April 30, 2018
Roberto,
Can you tell us what you were doing when you encountered the error?
Just to test, if you were to switch your language to English does the same occur?
Shannon
