Hi All,
we try to import a project in a JIRA but it fails because of plugin-related custom fields. You can see in the attached screenshot that there are 2 types of custom fields: the above fields van be "fixed", I guess by changing the custom field ID in the entitities xml of the import. But what about the 'Time in Status' custom field?? How can I import the project? Should I delete the field in the imported XML?
Thanks for help!
Rumi
Either in the source system or an intermediate system
Perform your export and it should import ok. You may need to perform a reindex to repopulate the values.
I reckon that you should not tamper with the XML data just yet, mate. Since there are possible bad implications if doing so.
I noticed that this has been raised as a bug in the project import and JIRA Charting plugin: https://jira.atlassian.com/browse/JRA-31434
Might as well ask the opinions of the developers in that issue.
