×I'm in the project administration and click on the Tempo-Link. After that I got an error and must return to Jira Home.
Error-Message:
Not Found (404)
No view for result [permissionviolation] exists for action [TempoProjectConfiguration!default]
Could not find what you were looking for. Maybe you should raise an issue.
I have the same message in hosting instance. It looks like some velocity template from tempo is missing
Tempo: 7.4.3#49, JIRA version: 5.1.5#784
Lars, at a first glance this looks like a permission problem. It doesn't seem to be a known bug. I'm not sure if you have already created a support ticket at support.atlassian.com. But if you didn't, I'd recommend you to do so. This way we could get a more deeper look in your instance and troubleshoot what's happening.
Bruno Rosa
