Error when starting JEMH 1.0 with JIRA 5.0
N
April 9, 2012
Hi all,
when I try to startup JIRA 5.0 I get the error
***********************************************************************************************The
following plugins failed to load:
JIRA Enterprise Mail Handler (JEMH): There was a problem loading the descriptor for module 'Transactional Annotation Processor' in plugin 'JIRA Enterprise Mail Handler (JEMH)'.
 Could not load class: com.atlassian.activeobjects.external.TransactionalAnnotationProcessor
in file atlassian-jira.log.
Any idea what I have to do
Norbert
Deleted user April 17, 2012
Hi Norbert,
To clarify, JIRA 5+ makes things a lot simpler such that you do not need to copy emh.properties into WEB-INF/classes, that route is now deprecated in favour of the database backed UI, and should not modify any XML service files, all required configuration can be done through the UI
I am still unable to reproduce your original scenario. I think your problem may be related to how you are trying to trigger JEMH. Don't try setting it as a service, that wont work:-
Following the doco, first need to setup an inbound mail service, once done you can associate a hander with it. JEMH provides a popup configuration screen from which you will need to select a JEMH Profile (configuration that you need to create).
In order to create a JEMH Profile, you need to access to the JEMH cnofiguration screens, which is done through the JIRA Administration screen, flick through the screenshots on plugin exchange for some idea of what to expect.
Cheers, Andy
N
April 17, 2012
Hi Andy,
thank you very much for your quick reply.
I get a evaluation license from javahollic and try to install the JEMH again like described. The first is I get further a ever was!
JIRA now starts to read the given mail with
Subject: #issuekey=PSMREG-202
Content:
@CT=not relevant
where I try to alter field CT in issue PSMREG-202.
The following error occured in the log file:
2012-04-18 15:36:10,441 QuartzWorker-1 ERROR ServiceRunner    JEMH Mail Handler [jira.emh.service.EnterpriseMessageHandlerImpl] Unhandled Exception occurred during processing (mail will be deleted (to stop re-processing) but forwarded), type=java.lang.NullPointerException), location=com.javahollic.jira.emh.service.DefaultJEMHConfigFactory.getConfiguration(DefaultJEMHConfigFactory.java:64).  This may be a BUG: null
Maybe you have an idea to that error?
Thanks.
Norbert
Deleted user April 18, 2012
OK, you should have then:
- install the plugin via the plugin exchange, and added your lincense key
- gone to the Profiles tab of the JEMH configuration screen and created your first profile
- created an inbound mail account
- registered an inbound mail handler for that account (JEMH), selecting the profile you created above.
Please clarify that you have done all this.
Observation: You have mixed directive formats that isnt supported, choose subject or email body.
To help your initial setup, set a default Project and reporter that has privilege in the project, such values are used as fallbacks but will help you get issues created and be able to see the results of your configuration changes.
N
April 23, 2012
Hi Andy,
thank for the description above.
Now the JEMH is running!
One question left so far: How can I give a folder like INBOX/Testemail where JEMH gets its emails for processing?
Any idea?
Norbert
Deleted user April 23, 2012
Glad to hear it! The 'folder' that you want is part of the mailbox configuration, rather than JEMH. According to this you can pick another folder with IMAP based servers.
N
April 23, 2012
Hi Andy,
now it works - thank you
The question is now anwered for me.
Norbert
N
April 17, 2012
with using JIRA 5.0.2 and JEMH 1.0.3 I don't get the error described in my original question.
But now, I don't know which handler I have to put in the service-file
com/atlassian/jira/service/services/mail/mailfetcherservice.xml
Here is my current configuration in the file
            <value>
              <key>com.javahollic.jira.emh.service.EnterpriseMessageHandlerProxy</key>
              <value>Extendable Mail Handler - EnterpriseMessage</value>
            </value>
but this generates error:
2012-04-18 12:46:19,828 ERROR [Default IMAP Server] QuartzWorker-1 ServiceRunner JEMH Email Handler JEMH Email Handler[10030]: Unhandled exception: com.javahollic.jira.emh.service.EMHProcessingFailureException: ProjectMapper failed to fixup projectDefaults: null, ProjectMapper failed to fixup projectDefaults: null
2012-04-18 12:46:19,836 ERROR [Default IMAP Server] QuartzWorker-1 ServiceRunner JEMH Email Handler JEMH Email Handler[10030]: Exception: JEMH cannot process mail, there are no configurations available.
java.lang.IllegalStateException: JEMH cannot process mail, there are no configurations available.
at com.javahollic.jira.emh.service.EnterpriseMessageHandlerImpl.handleMessage(EnterpriseMessageHandlerImpl.java:344)
at com.javahollic.jira.emh.service.EnterpriseMessageHandlerProxy.handleMessage(EnterpriseMessageHandlerProxy.java:43)
at com.atlassian.jira.service.services.mail.MailFetcherService$1.process(MailFetcherService.java:356)
at com.atlassian.jira.service.services.mail.MailFetcherService$MessageProviderImpl.getAndProcessMail(MailFetcherService.java:259)
at com.atlassian.jira.service.services.mail.MailFetcherService.runImpl(MailFetcherService.java:344)
at com.atlassian.jira.service.services.file.AbstractMessageHandlingService.run(AbstractMessageHandlingService.java:250)
at com.atlassian.jira.service.JiraServiceContainerImpl.run(JiraServiceContainerImpl.java:61)
at com.atlassian.jira.service.ServiceRunner.execute(ServiceRunner.java:47)
at org.quartz.core.JobRunShell.run(JobRunShell.java:195)
at com.atlassian.multitenant.quartz.MultiTenantThreadPool$MultiTenantRunnable.run(MultiTenantThreadPool.java:72)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:520)
Any idea?
Thank you for an answer.
Norbert
Deleted user April 9, 2012
Hi Norbert, strange to see that, I have 5.0 and 5.0.1 here (5.0.2 downloading!). JIRA 5+ ships with Active Objects, from whence this error came. I dont know the cause and haven't seen this before. Perhaps you could raise a support ticket at https://studio.plugins.atlassian.com/browse/JEMH as this is not the best place for diagnosing problems, a mroe complete logfile may help, and some context of your deployment?
