Error while running custom JQL function in ScriptRunner
Dhananjay Kale February 6, 2023
We are getting below error while running custom JQL function in ScriptRunner:
[Static type checking] - Cannot find matching method java.lang.Object#createLuceneQuery(com.atlassian.jira.jql.query.QueryCreationContext, com.atlassian.query.clause.Clause). Please check if the declared type is correct and if the method exists.
Here is the script for reference:
package com.onresolve.jira.groovy.jql
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.jql.query.LuceneQueryBuilder
import com.atlassian.jira.jql.query.QueryCreationContext
import com.atlassian.jira.jql.validator.NumberOfArgumentsValidator
import com.atlassian.jira.util.MessageSet
import com.atlassian.query.clause.TerminalClause
import com.atlassian.query.operand.FunctionOperand
import org.apache.lucene.search.Query
import java.text.MessageFormat
import com.atlassian.jira.web.bean.PagerFilter
class IssuesMovedToProject extends AbstractScriptedJqlFunction implements JqlQueryFunction {
     * Modify this query as appropriate.
     * See {@link java.text.MessageFormat} for details
    public static final String TEMPLATE_QUERY =
        "project = {0}"
    @Override
    String getDescription() {
        "Issues moved to specified project"
    @Override
    List<? extends Map> getArguments() {
                description: "Target Project",
                optional   : false,
    @Override
    String getFunctionName() {
        "issuesMovedToProject"
    def luceneQueryBuilder = ComponentAccessor.getComponent(LuceneQueryBuilder)
    def queryParser = ComponentAccessor.getComponent(JqlQueryParser)
    @Override
    Query getQuery(QueryCreationContext queryCreationContext, FunctionOperand operand, TerminalClause terminalClause) {
        def query = mergeQuery(operand)
        def searchService = ComponentAccessor.getComponent(SearchService.class)
        def user = ComponentAccessor.jiraAuthenticationContext.getLoggedInUser()
        List<Issue> issues = null
        def parseResult =  searchService.parseQuery(user, query.getQueryString())
        if (parseResult.isValid()) {
            def searchResult = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
            issues = searchResult.results
        } else {
            log.error("Invalid JQL: " + TEMPLATE_QUERY)
        def issueManager = ComponentAccessor.issueManager
        def issueList = new ArrayList<String>()
        issues.each{ Issue issue ->
            def allOtherKeys = issueManager.getAllIssueKeys(issue.id)?.findAll{it != issue.key}
            if (allOtherKeys?.size() > 0) {
                // hit, the issue had another key than the current one
                issueList.add(issue.key)
        def queryString = "issueKey in (" + issueList.join(",") + ")"
        def actualQuery = jqlQueryParser.parseQuery(queryString)
        return luceneQueryBuilder.createLuceneQuery(queryCreationContext, actualQuery.whereClause)      //getting error here
    private com.atlassian.query.Query mergeQuery(FunctionOperand operand) {
        def queryStr = MessageFormat.format(TEMPLATE_QUERY, operand.args.first())
        jqlQueryParser.parseQuery(queryStr)
Can you please look into it and share your thoughts?
Note: This script was working before JIRA upgrade (v8.13.24 from v7.*.*)
-DJ
Jeroen Poismans
Ok,
We'll start debugging :-).
First, change these lines:
To:
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
Because further in the code there are references to an unitialized variable.
Jeroen
Dhananjay Kale February 9, 2023
After changing these line, we get below errors now.
Cannot find matching method java.lang.Object#parseQuery(java.lang.String). Please check if the declared type is correct and if the method exists.
Jeroen Poismans
Never mind the red lines :-), does the code run?
Many thanks Jeroen.
the script started working now. (y)
-DJ
Jeroen Poismans
Can you:
  • Put the Code in a code block? Formats -> Code black
    Better readable then :-)
  • Give the line where the error occurs?
Jeroen
Thank you Jeroen.
Have updated code block. Please have a look.
I am getting error on below line
-DJ
Hello Jeroen,
Can I request you to look into?
-DJ
