Estimate not saving
Jim Bailey June 22, 2016
JIRA V6.4.11.
I can enter a Time Tracking estimate in the pop up window, but it is not saving. On the View/Edit page of my issue it shows:
Estimated  (then a grayed out progress bar) then Not Specified.
I can add a Log Work entry and it will show under Logged. Good.
'Remaining' stays at 0 hours with the grayed out progress bar.
Jim Bailey June 23, 2016
Silly me. I was using the wrong Original Estimate.
Oddly the good one  is called Time Tracking, and Original Estimate, depending on where you look.
Original Estimate (the other one) only has one name.
Yes.
Andrea Carl
June 22, 2016
Are you adding the estimate to the "original estimate" field?
