Since this week I am facing the problem that everytime I create an issues two issues are created.
Moreover I don't get a feedback that the issue was created after filling out all the fields and hitting the create button. The "create" form just loads for a second but shows no sign of change (all fields are still filled out).
When I then check if the issue was created in the backlog then not only one issue was created but two.
Did anyone encounter a similar problem or knows of a solution on how to fix this?
PS: The create another issue check-box is uncheck!!
