Exception not handled when SaveChanges in JIRA unhandled: System InvalidOperationException
Philippe Gendreau
January 27, 2018
I'm using v4.0.30319 SDK version
I have this following code, where I make some changes in an issue.
try
      Atlassian.Jira.Issue iss;
      //here incorrect change like: WorkflowTransitionAsync(iss, bUpdate); for example
      iss.SaveChanges();
catch (Exception err)
If the changes on the issue are incorrect, when I try to save them, I have an exception.
But this exception is unhandled (System.InvalidOperationException: 'Workflow action with name 'Resolve Issue' not found.'). As the exception is not unhandled in the code (doesn't go in the catch() section) , the program crash.
Would anybody knows how to handle the exception?
Thanks for your help,
Philippe
Abid Omer January 13, 2019
hii Philippe
Did you find anything because I have same issue.
