Exception while connecting to Jira soft. on my company's server via Java
Andrij November 9, 2017
Hi everyone :)
Im trying to get some data in JSON format using REST API of my company's Jira (ver. 6.4.13). This is for my Java application.
I can normally get needed data using browser, but got exception when trying to do this via Java program.
Getting exceprion: "javax.net.ssl.SSLProtocolException: handshake alert:  unrecognized_name" at last line of next code:
//url in String
String urlString = "https://jira.***/rest/api/2/search?jql=project=***&fields=key";
//building http connection
URL url = new URL(urlString);
//open connection
HttpURLConnection urlConnection = (HttpURLConnection)url.openConnection();
//set request method "GET"
urlConnection.setRequestMethod("GET");
//connect
urlConnection.connect();
Can anyone help me to break through this issue? I will thank you :)
Deyves
November 9, 2017
Hi Andrij,
The error you're facing is the same scenario being described on this article: https://confluence.atlassian.com/kb/applinks-will-not-locate-https-host-755336476.html
Usually this is caused by a new security feature implemented in Java 7 update 4, named Server Name Indication (SNI). The error means that the server has received a server_name extension request, but it doesn't recognize the server's name.
As described on RFC-4366, the error message may be fatal and we've seen reports of cases where this message would appear in a SSL troubleshooting process, but not cause any roadblocks on the Application Links configuration. So, we're still unsure as to in which cases this would cause a failure.
As a workaround, you can disable the SNI feature at Jira.
To do that you'll need to add a new parameter at the Jira startup options by following the steps from this article: [JIRA's startup parameters|https://confluence.atlassian.com/jira/setting-properties-and-options-on-startup-120007.html]
The flag is: "-Djsse.enableSNIExtension=false"
Nic Brough -Adaptavist-
November 9, 2017
Two minor technical points
1. the problem is a bug in Java that Oracle refuse to acknowledge
2. the fix is not a Jira thing, it applies to the JVM and hence the Tomcat that is running Jira.
