Exclude issue link from filter help
David Abowitt March 29, 2019
I have a filter that pulls action items from our RCA project that have not been completed yet. I was attempting to target issue link = "Is RCA Remediation" only but am also getting "Has RCA Remediation" type links in the filter. Thus, I don't want to capture or wish to exclude issue links of type "Has RCA Remediation. Any thoughts or assistance.
Here is my query:
issueFunction in hasLinkType("RCA Remediation") AND status not in (Done, Resolved, Abandoned, Closed) AND issue in linkedIssuesInQuery("issuetype in (Task, 'Root Cause Analysis') and statusCategory != Done ") AND issuetype not in ("Root Cause Analysis") ORDER BY due ASC, issuetype DESC, key ASC, cf[16524] ASC
David Abowitt April 8, 2019
@Fazila Ashraf and community sorry for late reply. So not sure what argument to use for haslinks. When I tried hasLinks("Has RCA Remediation") I get error occurred communicating with server. We are on-prem do I need scriptrunner installed as we don't have it installed.
Fazila Ashraf
Hi @David Abowitt
Please try with scriptrunner installed. It is a commercial plugin.
Are you sure you do not have scriptrunner already? The query in your question has 'issueFunction in' which is provided by scriptrunner.
David Abowitt April 17, 2019
I will check with my IT dept which manages the Jira environment. Will let you know.
@Fazila Ashraf we do have it installed server side. Thus, back to original question about error I am getting when using suggested command.
Fazila Ashraf
Hi @David Abowitt
Instead of hasLinkType , use hasLinks -> https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html#_haslinks
That takes the inward/outward linkname (Is RCA Remediation) as parameter.
