Existing issues not seen in project issues menu
Antonio Celso Dias Duarte March 31, 2015
The "main" project page says that my project has NO issues (see figure 1) but if I expand the issues option at the upper menubar, it shows the last issues seen in my project (see figure 2). If I click on any of these issues, it is open correctly (see figure 3).
Why my project says it has no issues?
How to fix it?
Figure 1
Figure 2
Figure 3
Nic Brough -Adaptavist-
March 31, 2015
Looks like the indexing is broken.  Could you try going to project admin -> reindex and see if that fixes it.
If it does, then you'll want to start looking into why the index was broken - how did you create the issues?
BINGO! Thanks, Nic, the reindex was successful and now everything goes right!
