Hi Team,
Has any of you encountered a situation to export / import a JIRA project with ~ 100000 issues? I know it sounds weird, however as it is a SD project, this number.
I tried this using the Configuration Manager app but somehow have not been successful so far. Export gets through, but the import gets stuck although I increased the proxy timeout.
I prefer using the UI, therefore having the environment cloning as a last resort.
Looking forward to your suggestions,
Thanks & Regards,
Janaki.
I recently imported a project around the same number of issues using Jira's native Project Import feature.
A few steps to get there:
It took a couple of hours but was completed successfuly.
If this answer helps solve the problem, please come back and mark this answer as solved to help other community members with the same challenge.
Alex
