I like the atlassian products but the tech in me needs to know if there is an out. Is there a way to export the data to keep offline. If atlassian goes under, if another products fits our needs better, can I get my data out of the cloud in a readable format?
I got stuck with an outdated version of MS TFS and in order to pull any usable data out of it it was thousands of dollars in upgrades or a text and file dump to be manually imported into another application.
I just want to know what I'm getting the company into before i sign a life long contract.
Thanks in advance.
Hi @Sean Dunaj ,
you have 2 options :
You can have a look at the document for both here : https://support.atlassian.com/jira-cloud-administration/docs/export-issues/
Let me know if this helps,
--Alexis
With our Excel exporter app, you can create any sort of Excel exports. The XLSX fileformat produced by it is reasonable for long-term storage for information.
You can find a selection of sample export here: https://www.midori-global.com/products/better-excel-exporter-for-jira/cloud/export-samples/
