Export specific custom fields from jira issues in specific format
Vishal
March 11, 2022
Hi Atlassian experts,
I have a custom issue type consisting of specific screen with the default fields like Summary, Priority & Description like fields along with lot of custom fields. I would like to export issue details for specific custom fields(not all) in a template which I need to forward to our supplier, is their a way to automate that somehow ? So, that the users can get those details just at the click of the button ?
If so, please suggest.
Thanks!
Sachin Dhamale
@Vishal ,
You can create a filter for the issues which you want to export the specific custom field
In the issue navigator > you can add a custom field which you want and remove unwanted custom field
Export section you can export the issue.
You can also subscribe that filter and add the supplier as recipients so they will get those custom field data.
Accept the answer if it helps
Fabio Racobaldo _Catworkx_
Hi @Vishal ,
you can create a specific filter with all custom fields as columns as per your needs and share it with users.
Keep in mind that you need to save your filter first and then setup columns in Filter tab.
Does it solve your requirement?
Fabio
