I am compiling a Product Health report and I require assistance on extracting all Business as Usual (BAU) tickets from JIRA in order to create a monthly report. Can anyone provide guidance on the process to accomplish this?
As previously mentioned, you can use JQL to filter BAU tickets and then export the results to CSV. Please remember that there is a standard Jira limit for exporting 1000 rows.
However, if you want to automate this process, we recommend our free app - Exporter for Jira. With this app, you can:
Our plugin supports the export of up to 20K issues with the free version, and you can upgrade to the PRO version for larger datasets.
We hope this helps! If you have any further questions or need assistance with our plugin, feel free to reach out.
Best regards,
theCode4 Team
You can easily:
This is a very core feature of the app.
If you want to make it even better you could try these:
(Discl. these apps are developed and supported by our team.)
Hi Emmanuel - Welcome to the Atlassian Community!
You would create query or filter. Then you can export the result of the filter to Excel.
