We are on Jira cloud. Now the question is as suppose I have Issue DP-1, DP-2, DP-3 now if I link DP-1 with DP-2 saying that DP-1 duplicates DP-2. When I try to extract the issue in CSV or HTML format, I am unable to track Linked Issue. I mean Linked Issue column is not present. So whats the solution for extract report with Linked Issue Column.
Hi Akshay,
You can have a column with the linked issues, the problem is more filtering them, but the column is avaiable try searching with different words.
