Extreme high load after opgrading to 8.17.1
Normann P_ Nielsen _Netic_
July 13, 2021
After upgrading to 8.17.1 the load on the ubuntu server spikes at +12 (normal around 2-5)
Automation took forever (50) min - https://confluence.atlassian.com/automation/upgrading-to-automation-for-jira-7-3-1055951956.html
We did not delete data first.
Also running Big Picture - opgrade tog +20 minutes for a "DB" upgrade.
Before and after:
July 14, 2021
Stop Jira
Take backup
Execute on the Database:
TRUNCATE AO_589059_AUTOMATION_QUEUE;
TRUNCATE AO_589059_AUDIT_ITEM_PROJECT;
TRUNCATE AO_589059_AUDIT_ITEM_ASC_ITEM;
TRUNCATE AO_589059_AUDIT_ITEM_CGE_ITEM;
TRUNCATE AO_589059_AUDIT_ITEM_COMP_CGE;
TRUNCATE AO_589059_AUDIT_ITEM;
TRUNCATE AO_589059_RULE_STAT;
TRUNCATE AO_589059_RULE_STAT_ROLLUP_DAY;
TRUNCATE AO_589059_RULE_STAT_ROLLUP_HR;
TRUNCATE AO_589059_RULE_STAT_ROLLUP_MIN;
Start Jira.
Load stabilised on 1.X
And we have set Audit logm expiry to 4 weeks
July 13, 2021
Disabling Jira Automation took load from +12 to 0-2 in 4-5 minutes
July 14, 2021
This is problkably why:
jira=# select count(*) from "AO_589059_AUTOMATION_QUEUE";
 count
   129
(1 row)
jira=# select count(*) from "AO_589059_AUDIT_ITEM_PROJECT";
  count
 18307910
(1 row)
jira=# select count(*) from "AO_589059_AUDIT_ITEM_ASC_ITEM";
  count
 5571251
(1 row)
jira=# select count(*) from "AO_589059_AUDIT_ITEM_CGE_ITEM";
  count
 54987603
(1 row)
jira=# select count(*) from "AO_589059_AUDIT_ITEM_COMP_CGE";
  count
 57835510
(1 row)
jira=# select count(*) from "AO_589059_AUDIT_ITEM";
  count
 29693626
(1 row)
jira=#
jira=# select count(*) from "AO_589059_RULE_STAT";
 count
 32077
(1 row)
jira=# select count(*) from "AO_589059_RULE_STAT_ROLLUP_DAY";
 count
 897587
(1 row)
jira=# select count(*) from "AO_589059_RULE_STAT_ROLLUP_HR";
 count
 216760
(1 row)
jira=# select count(*) from "AO_589059_RULE_STAT_ROLLUP_MIN";
 count
 32015
(1 row)
29 millions rows. Thats a lot. Unclear regarding these are index correctly
July 14, 2021
Well, actually 54 millions in one table
SERVER
VERSION
8.17.1
