Facing javascript problem while migrating from jira4.4 to jira5.X
jayasingh
We are planning to migrate jira4.4 to jira5.X in our organisation. we have implemented some of the customized functionality on custom fields through javascript. our script is working fine in jira4.4 but its not working in jira5.x. we have tried the below sites information but still not able to get the solution for this.
https://developer.atlassian.com/display/JIRADEV/Custom+Fields+that+use+CSS+or+JavaScript+Web+Resources+in+JIRA+5.0
https://answers.atlassian.com/questions/47843/strange-javascript-problem-in-create-screen
We would like to know is there any feature in Jira 5.x where the UI works like Jira 4.4. Can we acheive this by configuring any parameter in Jira 5.x.
Could you please suggest the solution for this.
RambanamP
December 4, 2012
try with following code if the first alert came then you need to check your logic
<script type="text/javascript">
jQuery(document).ready(function($) {
	JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) {
		callFunction();
		callFunction();
function callFunction(){
		alert("Test by Rambanam");
		$('#customfield_12661').focus(function(){
			 onFocusFunction();
	function onFocusFunction(){
	alert("in onfocus function");
			var testdefect = document.getElementById("customfield_12660");
			var w12 = testdefect.selectedIndex;
			var testvaldefect = testdefect.options[w12].text;
			var Maharashtra={"Select List": "-1", "Pune": "17890" ,"Nasik":"17158"};
			var Karnataka = {"Select List": "-1", "Hubli": "17159" ,"Banglore":"17160"};
			var phase={"Maharashtra": Maharashtra ,"Karnataka": Karnataka};
			var value = new Object();
			value = phase[testvaldefect];
			var count=0;
			defectIdval.innerHTML = "";
			for (var i in value)
				defectIdval.options[count] =new Option(i,value[i]);
				count++;
</script>
jayasingh
Hi Rambanam,
Thanks for your help.
I have tried this code but once i log out and login again the alert was not working for the first time. Second time its working fine.
Jayasingh
RambanamP
December 5, 2012
on which screen you tried and where you added javascript? i mean in plugin or field configuration?
jayasingh
I have created a custom field named state and city. In city custom field i have added this script inside field configuration. I havent used any plugin.
Jayasingh
jayasingh
The fields are added in all the screens through out the issue. Field is present in Create / Resolve / Close / Edit screen.
RambanamP
December 5, 2012
those fields are in create screen?
RambanamP
December 5, 2012
the javascript doesnt workin create screen while issuetype on change.
add javascript as web resource module in plugin then it will work in all screens.
i posted link im my first answer to know how to add javascript in plugin
jayasingh
Hi Rambanam,
AWWWWWWWW........ Javascript Functionality working fine in jira5.0.7.
Thanks for your continuos support. The sample script helped us to resolve the long pending issue.
Now we set for the migration of jira from 4.4 to 5.0
Jayasingh
RambanamP
November 19, 2012
Jaya singh,
Threre is no way to configure any parameters to work javascript in 5.x as in 4.4 because the UI changed lot from 4.x to 5.x, so you have to change your script according to the 5.x UI
I added lot of javascripts on 5.x as specified in the following post and all are working fine,
But as you said it is not working, what your tring to achive and what error your getting
Mizan
November 19, 2012
Hi Rambanam ,
I have javascript which works when i place it in the announcement banner but it does not work when i embed it in a web resource plugin . Can you please help
refer my question here
jayasingh
Hi Rambanam,
We have tried two scenario using plugin
1. Added web resource in atlassian-plugin.xml, Added JIRA.Events.NEW_CONTENT_ADDED and ajax based javascript inside the js file, removed javascript from field configuration.
after installing this plugin we are getting the output as below:
Output: At the time of issue creation ,when we clicked on Create Issue Link, it is opening new page same as old version of JIRA 4.4, we are able to see all the projects in the project dropdown and in the issue type dropdown we are getting all the project specific issue types.Dropdown functionality was working fine. But dropdowns w.r.to Dashboard, Issues, Project is not working. They are in disabled mode
2. Added web resource in atlassian-plugin.xml, Added JIRA.Events.NEW_CONTENT_ADDED and ajax based javascript inside the js file as well as in field configuration.
Output: At the time of issue creation, we are able to see all the projects in the project dropdown and in the issue type dropdown we are getting all the project specific issue types
Jayasingh.
RambanamP
November 20, 2012
can you share your code in js file and check that is there any error throwing javascript using firebug on firefox or javascript console on crome
jayasingh
Hi Rambanam,
Here is my javascript.
<script language="JavaScript" type="text/javascript">
var defectIdval = document.getElementById("customfield_12661");
alert("Test by Jai");
AJS.$(function()
defectIdval.onfocus=function()
var count=0;
count++;
AJS.$(".defectIdval", context).live("change keypress keydown", onfocus);
</script>
Here we have created two custom fields as state and city. once the user select the field state as Maharastra. in city dropdown it should show pune and nasik. once user select state as Karnataka it should display Hubli and Banglore.
Jayasingh
RambanamP
November 21, 2012
you need to remove <script > tag from the js file
i.e remove <script language="JavaScript" type="text/javascript"> and </script> tags
jayasingh
Hi Rambanam,
Thanks for your input.
I have tried removing the script tags from the plugin but still no luck and i have tried all the alternative ways still not working.
Jayasingh
jayasingh
Hi Rambanam,
I have tried two ways as per your suggestion
1.Updating my script inside the plugin and left the field config blank
2. Updating my script inside the field config and adding the web resource and
inside the js file. But still i am not able to get the solution for this.
when i right click the create issue and open it on new tab or new window its working fine.
Naren
November 19, 2012
jayasingh
Hi Naren,
I have tried many alternative ways but still no luck :-(
Jayasingh
atlassian, jira cloud certification, managing jira projects, jira project administration, jira cloud exam, atlassian certification, agile project management, jira workflows, jira permissions, jira training, jira cloud skills, atlassian learning
Become a Certified Jira Service Project Expert 🦸🏻‍♂️
Validate your expertise in managing Jira Service Projects for Cloud. Master configuration, optimize workflows, and manage users seamlessly. Earn global 🗺️ recognition and advance your career as a trusted Jira Service management expert.
Get Certified! ✍️
