Fahrenheit to Celsius conversion using dual drop down list . . .can it be done?
Deleted user August 6, 2018
Our customer would like something line a 2 part/section/dual list.
  1. on the left, numbers (a temperature)
  2. on the right, a F or C
the idea is for someone to see a temperature with a F or C next to it
AND
if you change a C to F OR F to C the temperature will adjust/change to F or C.
Can that be done? Is there a plugin that already does this?
Andy Heinzer
August 8, 2018
Interesting idea.  I have not seen this specific kind of request before.   I was thinking that perhaps it might be possible to create a javascript that you can put into a field description or the announcement banner that might be able to calculate the difference and change the field value when a user changes this other field.  But that's kinda tricky to even try to work though in my head.
Instead, I think it might be a more simple approach to use a plugin for Jira such as the Jira Misc Custom Fields.  This plugin allows you to create calculated custom fields, such as a Calculated number field.  It is not exactly the dynamic change you describe.  But it would allow you to have one custom field that is the temp in Fahrenheit, and in turn when that value is saved to the issue, and Jira reindexes the value there, the calculated custom field could then report the value in Celsius as well.   It might not be as elegant of a solution as I think you are looking for, this is one way that you could have a custom field shown on Jira issues to show both numeric values based on the conversion formula.
The way I envision this would be to use a numeric custom field, and not specifically a select (dropdown) field.  However you might be able to make this work with that field type as well.
Deleted user August 9, 2018
Andrew, Thanks for your input. I'll take a look at the Jira Misc Custom Fields.
briar lennox
July 25, 2025
Yes, that can definitely be done! You can use a simple dual list interface with a bit of JavaScript to auto convert between °C and °F when the unit changes. There are also plugins and components for this in most UI libraries 37 c to f.
