Importing failed because of one custom field is required. But I checked the this field .It dose exists in the csv file and have the valid value.
Bellowing is the error log
#####Detail Error Log#######################
2014-10-29 15:04:23,885 INFO - Importer started! 2014-10-29 15:04:23,885 INFO - Engine is running in Import mode 2014-10-29 15:04:23,887 INFO - All issues will be imported to project: Yangzi (YANGZI) 2014-10-29 15:04:23,887 INFO - Creating issue: ExternalIssue{externalId=autoid-7077618510165945860, summary=Import issue, issueType=Bug} 2014-10-29 15:04:23,897 WARN - Cannot add custom field value: null java.lang.NullPointerException at com.atlassian.jira.plugins.importer.imports.importer.impl.customfields.CFValueHandlerMultiple.handleOptionsHierarchy(CFValueHandlerMultiple.java:76) at com.atlassian.jira.plugins.importer.imports.importer.impl.customfields.CFValueHandlerMultiple.prepareCustomFieldValue(CFValueHandlerMultiple.java:40) at com.atlassian.jira.plugins.importer.imports.importer.impl.customfields.CustomFieldValueFactory.prepareRawValueForCustomField(CustomFieldValueFactory.java:63) at com.atlassian.jira.plugins.importer.imports.bulkcreate.BulkCreateCustomFieldsHelper.prepareValueForCustomFields(BulkCreateCustomFieldsHelper.java:47) at com.atlassian.jira.plugins.importer.imports.bulkcreate.BulkCreateDataImporter.handleCustomFields(BulkCreateDataImporter.java:351) at com.atlassian.jira.plugins.importer.imports.bulkcreate.BulkCreateDataImporter.externalIssueToInputParams(BulkCreateDataImporter.java:310) at com.atlassian.jira.plugins.importer.imports.bulkcreate.BulkCreateDataImporter.runImporterEngine(BulkCreateDataImporter.java:149) at com.atlassian.jira.plugins.importer.imports.bulkcreate.BulkCreateDataImporter.doImport(BulkCreateDataImporter.java:114) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:26) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:15) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:527) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:490) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303) at java.util.concurrent.FutureTask.run(FutureTask.java:138) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303) at java.util.concurrent.FutureTask.run(FutureTask.java:138) at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:253) at java.lang.Thread.run(Thread.java:662) 2014-10-29 15:04:23,898 WARN - Cannot add value to Custom Field [ Found By ]. Value [ {null=Beta test} ] cannot be found or is in incorrect format 2014-10-29 15:04:23,928 ERROR - Issue can't be created due to the error/s [ Found By is required. ]
Hi zhe,
It seems to be related with an invalid value to one of your custom fields, the "Found By", as you can see here:
You can either check what's the expect field value in your project, or if there's any other constraint that prevents this field to be correctly loaded.
Hope it helps!
