JIRA Access Constraints error. I've been testing the upgrade of our Jira instance from 4.4.4 to 5.2.2 in our dev environment and after rolling back to 4.4.4 from a failed 5.2.2 upgrade attempt, I get the following error.
Failed to start JIRA due to a build number inconsistency. The data present in your database is newer than the version of JIRA you are trying to startup. Database version is: 813 JIRA app version is: 664 Please use the correct version of JIRA. You are running: 4.4.4#664-r167664
I reverted back to a VM snapshot before the up/g of the server and a db back-up before the up/g. Can you advise what could be causing this issue? thanks
Ashmr,
The fail startup because JIRA 4.4.4 tried to connect to database that has been upgraded to 5.2.2. What I am suspecting in this case is that, even though the upgrade failed, the database was partially upgraded to 5.2.2.
Rolling back only can be done like https://confluence.atlassian.com/display/JIRA052/Rolling+Back+a+JIRA+Upgrade
Thanks Janet. The issue is that I restored the db to version prior to the up/g so it contains unchanged tables. I'll run through the oulined process and see if that fixes this - cheers
Are you using a fresh DB scheme for the upgrade ?
I used to use fresh DB scheme and install the latest JIRA using this scheme. Once the new JIRA is started, can import the xml from old one.
