I have created a custom field configuration but unsure how to apply in to a certain project.
the default field configuration is applied to all of our 5 projects
You should create a custom field configuration scheme, which consists of your custom field configurations.
The you should go to the Project Settings -> Fields -> Actions -> Choose a different scheme
@Kieron SangaMake a copy of default field configuration, associate field configuration with new scheme, then in project setting you can associate this scheme to the project!.
Best!
You are welcome!
