Field 'resolution' could not be used for sorting and will be skipped
Jyotsna Chimakurthi January 5, 2024
Above error message is getting repeatedly in out daily base logs. Could any on explain why this error occurs.
Craig Nodwell
Hi @Jyotsna Chimakurthi what log file is this showing up in?  And when?  Also as @Kavitha Chandrasekaran a screenshot of the actual error would help.
January 5, 2024
ho @Jyotsna Chimakurthi Can you post a screenshot of the operation you are trying to do and the error message? Thanks
