I am looking for a way to fill a custom field with input/text from a specific comment. For example:
Jira service request is submitted via portal or e-mail. Comment includes the string "Service ID: T10000". I would like to parse "Service ID: T10000" into a custom field called "ServiceID"
Hi @Lloyd Patawaran and...
You could probably use (Atlassian) Automation to do this:
Trigger is on "Issue created".
Condition is "Issue Fields Condition"
Update your custom field with that value.
HTH,
KGM
Hi @Lloyd Patawaran and welcome to the community!
...service request is submitted via portal or e-mail. Comment includes...
For the purposes of ensuring alignment on terminology, I'm assuming by "comment" you mean "Description"? The user does not have the ability to add a comment until after the issue has been created.
This would leverage Jira automation with regex. Can you please provide a sample of a description with this information so I can run through a quick test in my environment?
yes, it would be a comment after the issue is created. basically:
issue created.
issue is commented (not a description) with string "Service Case: SN1x******". We'd then parse that string into a custom field.
