I am looking to find all issues in a teams Q1 committed Epics.
So far I have come up with these filters
Project = ProjectX and Status != invalid and labels in (2022q1a, 2022q1b) and issueFunction in issuesInEpics("Project = 'ProjectX'")
Nothing is returned in the above filter, if I replace the AND with an OR before the issuesFunction all issues in the project are returned and I believe that is because of the OR
What is the syntax needed to combine the 2 filters ?
I would try something like this
issueFunction in issuesInEpics("project = ProjectX AND status != Invalid AND labels in (2022q1a,2022q1b)")
This is also assuming you have Scriptrunner installed which from the looks of your initial JQL, you probably do.
If you have our JQL Search Extensions, you can run:
issueFunction in childrenOfEpicsInQuery("project = ProjectX AND status != Invalid AND labels in (2022q1a,2022q1b)")
Make sure to check out more examples here.
