×In an EazyBI report, is it possible to filter the users by their Project Role?
Hi Anthony,
In the current version of eazyBI, it would not be possible to filter users by their JIRA project roles.
But thank you for this questions. We will discuss if to add this for one of the next versions of eazyBI.
Please contact support@eazybi.com if you have further questions regarding this!
Martins Vanags / support@eazybi.com
+1 to this feature request
+1
New dimensions "Assignee Project Role" and "Reporter Project Role" are available on eazyBI Cloud and since version 7.2.
Please see the documentation for more details: https://docs.eazybi.com/eazybi/data-import/data-from-jira/jira-core-measures-and-dimensions#JiraCoremeasuresanddimensions-Dimensions.
Go to the import options tab, "Additional options," and select the new dimensions for data import (https://docs.eazybi.com/eazybi/data-import/data-from-jira#DatafromJira-Additionaldimensionsforusergroups,intervals,andissuelinkfields). After the next data import, you can use the new dimension for your reports to group and filter data.
Best,
Zane / support@eazyBI.com
