Filter issue that has open linked issue(Blocked+Blocked By)
Vaishnavi Kulkarni June 11, 2021
There has been previous threads relating to this problem, however many provided old solution.
Could someone please suggest how can I achieve to filter issues in project that has linked issues that are blocking it and still unresolved.
I currently use
Project=xyz AND issueLinkType in (blocks,"is blocked by","depends on")
This gives me list of all linked issue irrespective of it's resolution.
Can anyone help me from this group? Thanks!
Muhammad Ramzan_Atlassian Certified Master_
June 14, 2021
Hi @Vaishnavi Kulkarni ,
I am afraid,  you can't by vanila jql. There are some adons which can support you.
Famous one's are
below is the example of JQL Search Extensions for Jira & repo
following query will return all linked issues which are not resolved
issue in linkedBy("is blocked by", "is related to", resolution = unresolved)
Reference
https://jqlsearchextensions.atlassian.net/wiki/spaces/SEARCH/pages/30497099/JQL+Reference+Server#JQLSearchExtensions(Server)-LinksCountLessThan
Hyrum Steffensen _Appfire_
June 11, 2021
Hello Vaishnavi,
If you are using Jira Server or Data Center, you can use Power Scripts JQL support to return issues based on link type. For example:
key in hasLinksOfType("project = EX AND status != Done", "Relates")
Please note that I a support engineer for Power Scripts and I work for Anova Apps, an Appfire company.
Hyrum
