×Hi all,
Is there a way that I can search for all users with a particular role type on my Jira cloud instance and export that list?
My use case is that I'd like to add all the Project Administrators from a list of Jira projects to an MS Teams team. I can manually inspect the membership and roles of each project one at a time but I'm thinking that there must be an easier (faster!) way to do this?
Hello @Adam Taylor ,
There is no API that can fetch this data, nor there is JQL query variable to use this.
You can refer to this page: https://community.atlassian.com/t5/Jira-Software-questions/JIRA-API-to-get-roles-by-User/qaq-p/2217790
BR,
Nikola
Try this API call:
https://<yourjirainstance>/rest/api/2/project/<projectID>/role/<roleID>
This should get you the "actors" in a specific role.
Method: GET
Hi @Adam Taylor
I think you can achieve the list by scripting but exporting won't be possible. Having said that you can export users in particular roles and project via script runner.
Hi @Adam Taylor
You can get this information per project but not overall.
