Unless I set period as Weekly/Monthly/.../ and so on, any of them shows correct number of issues resolved compared to the result of the link of first period. It shows different result of number ;(
Hi @Hotae Kim,
The resolution time gadget is configured to display the average of the number of days for which the resolved issues were open. The period needs to be set to view the timeframe for which this data is to be displayed.
If you feel that the gadget's data is incorrect, you can always click on any of the bar, find the corresponding issues in the issue navigator and check them.
Hope this helps!
Thanks!
