First Restart after Installation fails
Michael Grabow October 2, 2017
After Installation of JIRA <atlassian-jira-software-7.5.0-x64.bin> and a Restart of my Ubuntu access to my JIRA-instance fails.
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.3 LTS"
catalina.out ->
02-Oct-2017 22:30:41.514 SCHWERWIEGEND [Catalina-startStop-1] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: /opt/atlassian/jira/conf/Catalina/localhost
02-Oct-2017 22:30:41.527 SCHWERWIEGEND [Catalina-startStop-1] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: /opt/atlassian/jira/conf/Catalina/localhost
02-Oct-2017 22:30:41.545 SCHWERWIEGEND [Catalina-startStop-1] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: /opt/atlassian/jira/conf/Catalina/localhost
02-Oct-2017 22:30:41.562 SCHWERWIEGEND [Catalina-startStop-1] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: /opt/atlassian/jira/conf/Catalina/localhost
02-Oct-2017 22:30:41.611 SCHWERWIEGEND [Catalina-startStop-1] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: /opt/atlassian/jira/conf/Catalina/localhost
02-Oct-2017 22:30:41.645 SCHWERWIEGEND [Catalina-startStop-1] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: /opt/atlassian/jira/conf/Catalina/localhost
2017-10-02 22:31:32,201 localhost-startStop-1 INFO      [c.a.jira.startup.JiraHomeStartupCheck] The jira.home directory '/var/atlassian/application-data/jira' is validated and locked for exclusive use by this instance.
2017-10-02 22:31:33,426 JIRA-Bootstrap INFO      [c.a.jira.startup.JiraStartupLogger]
    JIRA starting...
It looks for me as a permission problem.
The installation was made as 'root' (sudo -iu root)
I have choosed the 'custom' installation, have left all as standard and answer the question for installing as a service with 'yes'
Some more information:
After executing
/opt/atlassian/jira/bin# ./start-jira.sh
all seems fine, only automatic start isn't still able.
