Fisheye running with the same JIRA hostname
Darly Senecal-Baptiste
February 23, 2014
Hi Community:
I was applying the following:
In Jira (War Installation) I was setting the proxy with its proxyName=jiradev.example.comat the server.xml file (also with the scheme and port). And at apache I was using the following
<VirtualHost *:80>
ServerName jiradev.example.com
#SSLProxyEngine On
ProxyRequests   Off
ProxyPreserveHost       On
ProxyPass       /       http://server_url:8080/jira
ProxyPassReverse /  http://server_url:8080/jira
#ProxyPass /crucible http://e1dmiscvap01.ert.com:8060/crucible
#ProxyPassReverse /crucible http://e1dmiscvap01.ert.com:8060/crucible
 <Proxy *>
    Order deny,allow
    Allow from all
 </Proxy>
<Location /jira>
 Order allow,deny
 Allow from all
</Location>
</VirtualHost>
Now, I want to add Fishsye (with the /curcible context), under the same apache server. So I performed the following at fisheye's config.xml file
<web-server site-url="http://e1dmiscvap01.ert.com:8060/crucible" context="/crucible">
        <http bind=":8060" proxy-port="443" proxy-scheme="https" proxy-host="jiradev.example.com"/>
      <ssl keystore-password="OBF:1bw21y7z1wui1gfp1gg91wtw1y7z1bws" bind=":6443" truststore-password="OBF:1bw21y7z1wui1gfp1gg91wtw1y7z1bws" truststore="/crucible/fis_keystore.kst" keystore="/crucible/fis_keystore.kst"><proxy-info proxy-host="jiradev.ert.com" proxy-port="443" proxy-scheme="https"/></ssl>  </web-server>
And I added the following line under JIRA's VirtualHost at apache
Stopped JIRA and Fisheye and reloaded apache. Started JIRA, then Crucible. Acceesed JIRA with cannonical URL, it works. However, looking for crucible with jiradev.example.com/crucible, it throws me a 404 error from tomcat.
What did I do wrong and how to resolve that.
PS: Also, I want to add the same cannonical URL to git and svn as well
lpater
March 3, 2014
Hi Darly,
seeing a 404 error from tomcat seems to indicate that apache directs the request to /crucible to JIRA instead of Crucible (which uses Jetty internally).
Looking at http://httpd.apache.org/docs/2.2/mod/mod_proxy.html#proxypassit seems that the order of the ProxyPass directives matters, and that the first matching one is applied (in your case that would be the 'ProxyPass /' one). The docs mention that you should generally order them from the longest url to the shortest.
Could you try putting the 'ProxyPass /crucible' rules first and see if that helps you resolve your issue?
March 6, 2014
Thanks Lukasz. I realized that my server was mimicked by a load balancing system. One of my sysadmin made the proper change and now it's working. Thanks again
