Trying to install tfs4jira, however the asp.net 4.5 or newer check is failing.
We have installed this a number of times and it still fails.
Hi Boranprasit,
You have to enable ASP.NET 4.5 feature for IIS in Programs in Control Panel - see documentation for more details - https://confluence.spartez.com/display/TFS4JIRA/Prerequisites
Resolved. asp.net 4.5 was installed and running. Re-installing it from command line did the trick. Thank you for the input though Michal.
