Force ticket status and solution datetime
Rida
May 20, 2015
Is there a way to force project member to SET a ticket status (e.g. accepted) AND forecast a solution entering a date and time?
Best regards,
M
You can make the field "solution datetime" required in the field configuration.
Statuses are from the workflow. I'm not sure what you mean by forcing a project member to set the status.
