Format dropdown is blank for Jenkins Jira Configuration
Jira_User
August 6, 2020
1. I have installed the Xray plugin in Jenkins
2. I have installed the Xray app in Jira
3. I have configured the Jenkins system with Xray API keys(Server/data center) and "Test connection" is passed
4. In Jenkins, I chose "Xray: Results Import task" option in the Post-build Actions and selected the Jira instance
Observed result: When I am going to select Format field, It shows empty
Expected result: It supposed to show list of Json results to import/formats
May i know what is missed here ?
Sergio Freire - Xblend
August 14, 2020
Hi @Jira_User
We are not able to replicate it in our side. We need more details from your side, to be able to investigate it. I recommend you to reach out to Xray support.
Best Regards,
Sérgio Freire, Solution Architect and Testing Advocate @Xray
Personal blog on testing, Agile and software development: https://sergiofreire.com
Follow me on Twitter: https://twitter.com/darktelecom
