Formatting does not work across lines.
Deleted user April 10, 2018
Any idea why formatting doesn't function as expected, when a linebreak is within the text to be formatted, in a JIRA ticket comment?
Deleted user April 11, 2018
Hi Chung.
I submitted it as feedback when I discovered it.
If I add a comment to an issue in JIRA, and I format the text of the comment, it does not consistently work.
_split comment_   << that will be italicized.
_split
comment_     << that will NOT be italicized.  Instead, I would have to do:
_split_
_comment_
Chung Park Chan
April 24, 2018
It's a feature that has been marked as Won't Fix - JRASERVER-59216
Chung Park Chan
April 10, 2018
Hey Darryl,
Do you have any example on this? That would give us a better representation of the formatting.
Cheers
