Is there a free method in JIRA, beyond automation rules, where I can modify the value of one field based on another field, possibly from an external source outside of JIRA Software
Unfortunately, Jira itself doesn't offer a free built-in method to modify a field value based on another field from an external source without automation rules. However, there are a few options you can consider:
This is the most straightforward solution. The Automation for Jira app allows you to create rules that trigger actions based on specific conditions. You can configure a rule to update a field based on the value of another field or data received from an external source via webhooks or APIs.
ScriptRunner allows you to write custom scripts (Groovy or JavaScript) to automate tasks in Jira. You can create a script that listens for issue events (like issue creation or field update) and modifies another field based on the updated value or by fetching data from an external source using the script's capabilities.
If you have some development expertise, you can develop a custom integration between Jira and your external source. This could involve building a script or application that monitors the external source for changes and triggers an update in Jira using its REST API.
While not ideal for complex logic, Jira workflows offer limited field manipulation capabilities. You can configure post-function conditions in a workflow transition to update a field based on the value of another field selected during the transition. However, this won't work for data from an external source.
Free Alternatives (Limited Functionality)
Choosing the right approach depends on your specific needs and technical expertise. If you need a simple solution and don't mind paid apps, Automation for Jira is a good choice. For more complex scenarios or integrations with external sources, ScriptRunner or custom integrations might be necessary.
Could you please elaborate step by step how can I proceed with Custom Integrations?
Here's a step-by-step breakdown of how you can proceed with custom integrations to modify a field value in Jira based on an external source:
1. Define Requirements
2. Choose Development Approach
There are two main approaches to building the custom integration:
3. Development Steps
4. Testing and Deployment
Important Considerations:
Additional Resources
Jira REST API Documentation
Apache Camel
MuleSoft
Remember: Building a custom integration requires technical expertise and understanding of APIs and scripting languages. If this is outside your comfort zone, consider exploring paid options like Automation for Jira or consulting a developer for assistance.
