Freeze or Archive a project with no activity under 2 weeks
KMEROVIL January 23, 2023
Hi everyone,
I'd like to create an automation rule.
Our goal is to freeze a project without activity under 2 weeks, then archive this project if there is no activity during 4 weeks.
Do you think this rule could be set?
Could you please help me?
Best regards
Karim
Nicolas Tagle
January 23, 2023
Hi Kmerovil,
There is no automation rule that will allow you to do a freeze or archive a project, those are administrative task meant to be done by a Jira Admin.
sorry for not being more useful. Cheers,
Nico
KMEROVIL January 24, 2023
Hi @Nicolas Tagle
Thanks so much for your feedback.
I guessed this move was not possible but we never know.
Thanks for your help.
Karim
Like Nicolas Tagle likes this
Vamsi Kandala
January 23, 2023
Hi @KMEROVIL
Welcome to the community!
Which version of Jira are you using?
As mentioned by @Nicolas Tagle there is no out-of-the-box feature to do this automatically.
In Jira 8.20.x onwards, there is a 'Clean up' option in the 'System' section where you can sort the projects by when the issue/ ticket was last created and archive them accordingly.  Unfortunately, this is a manual process.
Please refer to this as well: https://confluence.atlassian.com/clean/cleanup-guide-1018788576.html
Hope this helps.
Vamsi
Hi @Vamsi Kandala ,
Thanks so much for your feed back.
I am using the 8.20 Datacenter version.
I'll try it and let you know.
Best regards
Karim
