Fresh Jira - EKS installation running into issues starting Jira
Lloyd Kim November 11, 2024
That is the error I am getting, and not exactly sure how to get around it via EKS environment.  Any help appreciated.
This is a brand new installation, and not exactly sure if I am supposed to go to a page to configure the database or initialize the database.  The load balancer and the target group is showing unhealthy, so I am not able to get to the site via the ALB.  Is there something I am missing?  Thanks again for any ideas
  ___ Starting the JIRA Plugin System _________________ 2024-11-11 21:31:31,480+0000 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbcon fig.xml 2024-11-11 21:31:31,528+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running Jira startup checks. 2024-11-11 21:31:31,528+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Jira pre-database startup checks completed successfully. 2024-11-11 21:31:31,564+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is not yet configured. Enqueuing Database Checklist Launcher on po st-database-configured-but-pre-database-activated queue 2024-11-11 21:31:31,565+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is not yet configured. Enqueuing Post database-configuration launc hers on post-database-activated queue 2024-11-11 21:31:31,576+0000 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Startup is complete. Jira is ready to serve. 2024-11-11 21:31:31,578+0000 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Instead of localhost on EKS cluster you need to go to the pod ip address on port 8080.  This allowed me to go and configure the database and JIRA.
SERVER
