Fresh jira installation : Application context initialization for 'com.atlassian.gadgets.dashboard' has timed out
Christophe Gravier
I am trying to set up a stand alone jira instance.
The Jira is supposed to run behind a apache server and using a mysql backend.
These connections seems fine, however, when I try to launch jira some plugins failed to install (dashboard to beginin with), due to a "timeout".
What is this timeout ? Is it requiring some heavy I/O or is it running a possibly long process (in this case is it possible to increase the timeout ?)
When the process complete, I receive :
The following plugins are required by JIRA, but have not been started: Embedded Gadgets Plugin (com.atlassian.gadgets.embedded), Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard), Gadget Directory Plugin (com.atlassian.gadgets.directory), Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
And i cannot access to jira.
I tried to remove $JIRA_HOME/plugins/.osgi_plugins and .bundled_plugins and restart as I read it on another issue on the board, with no success.
Here is the entire stack trace that is given by JIRA log below.
The box is runnign the latest ubuntu LTS. Other jira-related and software versions are in the trace (is there some knwon incompatibilities that are leading to timeouts ?).
Does anyone encounter this before ?
Thanks you in advance for any clue !
JIRA starting...
2013-04-06 21:36:53,185 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 5.2.10#853-sha1:c0ba2680a6a588d5657e1aadb3169a8dbf69984f
Build Date : Tue Apr 02 00:00:00 CEST 2013
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/7.0.29 - Servlet API 3.0
Java Version : 1.7.0_17 - Oracle Corporation
Current Working Directory : /opt/atlassian/deployed/atlassian-jira-5.2.10-standalone/bin
Maximum Allowable Memory : 1979MB
Total Memory : 989MB
Free Memory : 890MB
Used Memory : 99MB
Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 1721472(1681K) committed = 2555904(2496K) max = 50331648(49152K)
Memory Pool: Eden Space : Eden Space: init = 286326784(279616K) used = 59195864(57808K) committed = 286326784(279616K) max = 572653568(559232K)
Memory Pool: Survivor Space : Survivor Space: init = 35782656(34944K) used = 35782648(34943K) committed = 35782656(34944K) max = 71565312(69888K)
Memory Pool: Tenured Gen : Tenured Gen: init = 715849728(699072K) used = 9132272(8918K) committed = 715849728(699072K) max = 1431699456(1398144K)
Memory Pool: Perm Gen : Perm Gen: init = 21757952(21248K) used = 18043552(17620K) committed = 21757952(21248K) max = 268435456(262144K)
JVM Input Arguments : -Djava.util.logging.config.file=/opt/atlassian/deployed/jira/conf/logging.properties -XX:MaxPermSize=256m -Xms1024m -Xmx2048m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -XX:+PrintGCDateStamps -Djira.home=/home/jira -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.endorsed.dirs=/opt/atlassian/deployed/jira/endorsed -Dcatalina.base=/opt/atlassian/deployed/jira -Dcatalina.home=/opt/atlassian/deployed/jira -Djava.io.tmpdir=/opt/atlassian/deployed/jira/temp
___ Java System Properties _________________
atlassian.standalone : JIRA
awt.toolkit : sun.awt.X11.XToolkit
catalina.base : /opt/atlassian/deployed/jira
catalina.home : /opt/atlassian/deployed/jira
catalina.useNaming : true
common.loader : ${catalina.base}/lib,
${catalina.base}/lib/*.jar,
${catalina.home}/lib,
${catalina.home}/lib/*.jar
file.encoding : UTF-8
file.encoding.pkg : sun.io
java.awt.graphicsenv : sun.awt.X11GraphicsEnvironment
java.awt.headless : true
java.awt.printerjob : sun.print.PSPrinterJob
java.class.version : 51.0
java.home : /usr/lib/jvm/java-7-oracle/jre
java.io.tmpdir : /opt/atlassian/deployed/jira/temp
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.runtime.name : Java(TM) SE Runtime Environment
java.runtime.version : 1.7.0_17-b02
java.specification.name : Java Platform API Specification
java.specification.vendor : Oracle Corporation
java.specification.version : 1.7
java.util.logging.config.file : /opt/atlassian/deployed/jira/conf/logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : Oracle Corporation
java.vendor.url : http://java.oracle.com/
java.vendor.url.bug : http://bugreport.sun.com/bugreport/
java.version : 1.7.0_17
java.vm.info : mixed mode
java.vm.name : Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Oracle Corporation
java.vm.specification.version : 1.7
java.vm.vendor : Oracle Corporation
java.vm.version : 23.7-b01
jira.home : /home/jira
mail.mime.decodeparameters : true
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
os.arch : amd64
os.name : Linux
os.version : 3.2.0-39-generic
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : /usr/lib/jvm/java-7-oracle/jre/lib/amd64
sun.cpu.endian : little
sun.cpu.isalist :
sun.io.unicode.encoding : UnicodeLittle
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : UTF-8
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
sun.os.patch.level : unknown
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.DefaultJarScanner.jarsToSkip : bootstrap.jar,
commons-daemon.jar,
tomcat-juli.jar,
annotations-api.jar,
el-api.jar,
jsp-api.jar,
servlet-api.jar,
catalina.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-tribes.jar,
jasper.jar,
jasper-el.jar,
ecj-*.jar,
tomcat-api.jar,
tomcat-util.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-jni.jar,
tomcat-spdy.jar,
tomcat-i18n-en.jar,
tomcat-i18n-es.jar,
tomcat-i18n-fr.jar,
tomcat-i18n-ja.jar,
tomcat-juli-adapters.jar,
catalina-jmx-remote.jar,
catalina-ws.jar,
tomcat-jdbc.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
jstl.jar,
geronimo-spec-jaxrpc*.jar,
wsdl4j*.jar,
ant.jar,
ant-junit*.jar,
aspectj*.jar,
jmx.jar,
h2*.jar,
hibernate*.jar,
httpclient*.jar,
jmx-tools.jar,
jta*.jar,
log4j*.jar,
mail*.jar,
slf4j*.jar,
xercesImpl.jar,
xmlParserAPIs.jar,
xml-apis.jar,
dnsns.jar,
ldapsec.jar,
localedata.jar,
sunjce_provider.jar,
sunmscapi.jar,
sunpkcs11.jar,
jhall.jar,
tools.jar,
sunec.jar,
zipfs.jar,
apple_provider.jar,
AppleScriptEngine.jar,
CoreAudio.jar,
dns_sd.jar,
j3daudio.jar,
j3dcore.jar,
j3dutils.jar,
jai_core.jar,
jai_codec.jar,
mlibwrapper_jai.jar,
MRJToolkit.jar,
vecmath.jar,
junit.jar,
junit-*.jar,
ant-launcher.jar
user.country : FR
user.dir : /opt/atlassian/deployed/atlassian-jira-5.2.10-standalone/bin
user.home : /home/jira
user.language : fr
user.name : jira
user.timezone : Europe/Paris
2013-04-06 21:36:53,260 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2013-04-06 21:36:53,510 localhost-startStop-1 INFO [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory '/home/jira' is validated and locked for exclusive use by this instance.
2013-04-06 21:36:53,519 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2013-04-06 21:36:54,464 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /home/jira/dbconfig.xml
2013-04-06 21:36:54,912 localhost-startStop-1 INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Database Checklist Launcher
2013-04-06 21:37:01,638 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Name is MySQL
2013-04-06 21:37:01,639 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Version is 5.5.29-0ubuntu0.12.04.2
2013-04-06 21:37:01,640 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Name is MySQL-AB JDBC Driver
2013-04-06 21:37:01,640 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Version is mysql-connector-java-5.1.24 ( Revision: ${bzr.revision-id} )
2013-04-06 21:37:04,101 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseChecklistLauncher] JIRA database startup checks completed successfully.
2013-04-06 21:37:04,104 localhost-startStop-1 INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Post database-configuration launchers
2013-04-06 21:37:07,376 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /home/jira/dbconfig.xml
2013-04-06 21:37:10,211 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseLauncher] Database transactions enabled: true
2013-04-06 21:37:10,220 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2
2013-04-06 21:37:10,229 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
Database configuration OK
___ Database Configuration _________________
Loading entityengine.xml from : file:/opt/atlassian/deployed/atlassian-jira-5.2.10-standalone/atlassian-jira/WEB-INF/classes/entityengine.xml
Entity model field type name : mysql
Entity model schema name :
Database Version : MySQL - 5.5.29-0ubuntu0.12.04.2
Database Driver : MySQL-AB JDBC Driver - mysql-connector-java-5.1.24 ( Revision: ${bzr.revision-id} )
Database URL : jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB
Database JDBC config : mysql jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB
2013-04-06 21:37:13,909 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Starting the JIRA Plugin System _________________
2013-04-06 21:37:13,916 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Initialising the plugin system
2013-04-06 21:38:01,695 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/activeobjects-jira-spi-0.19.16.jar (1364879814000) created
2013-04-06 21:38:01,964 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/activeobjects-plugin-0.19.16.jar (1364879812000) created
2013-04-06 21:38:02,428 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/applinks-plugin-3.10.4.jar (1364879784000) created
2013-04-06 21:38:02,666 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-admin-quicksearch-jira-1.1.1.jar (1364879810000) created
2013-04-06 21:38:02,716 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-bot-killer-1.7.2.1.jar (1364879810000) created
2013-04-06 21:38:02,824 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-custom-apps-plugin-1.15.jar (1364879814000) created
2013-04-06 21:38:03,020 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-gadgets-dashboard-plugin-3.2.0-m2-1.jar (1364879812000) created
2013-04-06 21:38:03,105 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-gadgets-directory-plugin-3.2.0-m2-1.jar (1364879814000) created
2013-04-06 21:38:03,198 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-gadgets-embedded-plugin-3.2.0-m2-1.jar (1364879814000) created
2013-04-06 21:38:03,255 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-gadgets-oauth-service-provider-plugin-3.2.0-m2-1.jar (1364879814000) created
2013-04-06 21:38:03,537 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-gadgets-opensocial-plugin-3.2.0-m2-1.jar (1364879814000) created
2013-04-06 21:38:03,700 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-gadgets-publisher-plugin-3.2.0-m2-1.jar (1364879814000) created
2013-04-06 21:38:04,076 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-jira-rpc-plugin-5.1.3.jar (1364879814000) created
2013-04-06 21:38:04,224 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-nav-links-plugin-1.3.16.jar (1364879814000) created
2013-04-06 21:38:04,421 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-oauth-admin-plugin-1.6.1.jar (1364879814000) created
2013-04-06 21:38:04,486 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-oauth-consumer-plugin-1.6.1.jar (1364879812000) created
2013-04-06 21:38:04,565 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-oauth-consumer-spi-1.6.1.jar (1364879682000) created
2013-04-06 21:38:04,753 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-oauth-service-provider-plugin-1.6.1.jar (1364879814000) created
2013-04-06 21:38:04,803 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-oauth-service-provider-spi-1.6.1.jar (1364879678000) created
2013-04-06 21:38:04,953 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-rest-module-compat25-5.2.10.jar (1364880248000) created
2013-04-06 21:38:05,006 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-template-renderer-api-1.4.2.2.jar (1364879666000) created
2013-04-06 21:38:05,181 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-template-renderer-velocity16-plugin-1.4.2.2.jar (1364879666000) created
2013-04-06 21:38:05,843 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/atlassian-universal-plugin-manager-plugin-2.7.10.jar (1364879810000) created
2013-04-06 21:38:06,446 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/auiplugin-5.0-m10.jar (1364879812000) created
2013-04-06 21:38:06,474 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/com.springsource.com.sun.syndication-0.9.0.jar (1364879810000) created
2013-04-06 21:38:06,500 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/com.springsource.org.jdom-1.0.0.jar (1364879810000) created
2013-04-06 21:38:06,537 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/crowd-rest-application-management-2.4.9.jar (1364879724000) created
2013-04-06 21:38:06,560 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/crowd-rest-plugin-2.4.9.jar (1364879724000) created
2013-04-06 21:38:06,597 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/embedded-crowd-admin-plugin-1.4.5.jar (1364879814000) created
2013-04-06 21:38:06,633 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/hipchat-for-jira-plugin-1.1.13.jar (1364879810000) created
2013-04-06 21:38:06,654 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/httpclient-osgi-4.0.jar (1364879814000) created
2013-04-06 21:38:06,673 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/httpcore-osgi-4.0.jar (1364879812000) created
2013-04-06 21:38:06,723 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/icu4j-3.8-1.jar (1364879812000) created
2013-04-06 21:38:06,795 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-admin-helper-plugin-1.6.jar (1364879814000) created
2013-04-06 21:38:06,831 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-admin-summary-plugin-5.2.10.jar (1364880270000) created
2013-04-06 21:38:06,851 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-application-properties-plugin-5.2.10.jar (1364880270000) created
2013-04-06 21:38:07,083 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-bamboo-plugin-5.2.1.jar (1364879812000) created
2013-04-06 21:38:07,146 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-baseurl-plugin-1.9.jar (1364879814000) created
2013-04-06 21:38:07,468 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-fisheye-plugin-5.2.9.jar (1364879812000) created
2013-04-06 21:38:07,546 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-gadgets-plugin-5.2.10.jar (1364880266000) created
2013-04-06 21:38:07,627 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-header-plugin-5.2.10.jar (1364880294000) created
2013-04-06 21:38:07,653 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-help-tips-0.29.jar (1364879810000) created
2013-04-06 21:38:07,665 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-ical-feed-1.0.12.jar (1364879810000) created
2013-04-06 21:38:07,790 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-importers-plugin-5.0.3.jar (1364879814000) created
2013-04-06 21:38:07,849 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-invite-user-plugin-1.6.jar (1364879814000) created
2013-04-06 21:38:07,954 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-issue-collector-plugin-1.2.9.jar (1364879810000) created
2013-04-06 21:38:07,969 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-issue-link-applinks-common-plugin-5.2.10.jar (1364880302000) created
2013-04-06 21:38:08,036 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-issue-link-confluence-plugin-5.2.10.jar (1364880308000) created
2013-04-06 21:38:08,117 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-issue-link-remote-jira-plugin-5.2.10.jar (1364880302000) created
2013-04-06 21:38:08,177 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-issue-link-web-plugin-5.2.10.jar (1364880304000) created
2013-04-06 21:38:08,386 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-issue-nav-plugin-1.1.25.21.jar (1364879814000) created
2013-04-06 21:38:08,403 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-json-rpc-plugin-1.0.4.jar (1364879810000) created
2013-04-06 21:38:08,489 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-language-pack-de_DE-5.2.8-v2r5721-2013-03-15.jar (1364879812000) created
2013-04-06 21:38:08,504 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-language-pack-es_ES-5.2.8-v2r12795-2013-03-15.jar (1364879812000) created
2013-04-06 21:38:08,519 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-language-pack-fr_FR-5.2.8-v2r2373-2013-03-15.jar (1364879812000) created
2013-04-06 21:38:08,534 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-language-pack-ja_JP-5.2.8-v2r15554-2013-03-18.jar (1364879810000) created
2013-04-06 21:38:08,547 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-languages-5.2.10-en_UK.jar (1364880232000) created
2013-04-06 21:38:08,561 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-languages-5.2.10-en_US.jar (1364880232000) created
2013-04-06 21:38:08,620 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-lookandfeel-plugin-5.2.10.jar (1364880274000) created
2013-04-06 21:38:08,729 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-mail-plugin-5.2.21.1.jar (1364879814000) created
2013-04-06 21:38:08,756 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-monitoring-plugin-05.5.4.jar (1364879814000) created
2013-04-06 21:38:08,781 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-my-home-plugin-5.2.10.jar (1364880298000) created
2013-04-06 21:38:08,793 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-oauth-consumer-spi-plugin-5.2.10.jar (1364880252000) created
2013-04-06 21:38:08,803 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-oauth-service-provider-spi-plugin-5.2.10.jar (1364880250000) created
2013-04-06 21:38:09,144 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-project-config-plugin-5.2.10.jar (1364880268000) created
2013-04-06 21:38:09,221 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-quick-edit-plugin-1.0.54.jar (1364879814000) created
2013-04-06 21:38:09,261 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-rest-plugin-5.2.10.jar (1364880264000) created
2013-04-06 21:38:09,297 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-sal-plugin-5.2.10.jar (1364880268000) created
2013-04-06 21:38:09,333 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-share-plugin-5.2.10.jar (1364880300000) created
2013-04-06 21:38:09,358 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-soy-plugin-5.2.10.jar (1364880270000) created
2013-04-06 21:38:09,384 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-tzdetect-plugin-1.6.jar (1364879814000) created
2013-04-06 21:38:09,404 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-user-profile-plugin-1.1.0.jar (1364879814000) created
2013-04-06 21:38:09,504 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-view-issue-plugin-5.2.10.jar (1364880272000) created
2013-04-06 21:38:09,547 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-webhooks-plugin-1.0.8.jar (1364879810000) created
2013-04-06 21:38:09,645 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/jira-welcome-plugin-1.1.34.jar (1364879810000) created
2013-04-06 21:38:09,669 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/json-20070829-1.jar (1364879810000) created
2013-04-06 21:38:09,724 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/mywork-common-plugin-1.1.9.jar (1364879812000) created
2013-04-06 21:38:09,739 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/mywork-jira-provider-plugin-1.1.9.jar (1364879810000) created
2013-04-06 21:38:09,752 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/nekohtml-1.9.12-1.jar (1364879812000) created
2013-04-06 21:38:10,752 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/remoteapps-plugin-0.4.518.3.jar (1364879812000) created
2013-04-06 21:38:10,787 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/rome-1.0.jar (1364879810000) created
2013-04-06 21:38:10,859 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/soy-template-plugin-1.1.3.jar (1364879712000) created
2013-04-06 21:38:10,944 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/stp-3.0.11.jar (1364879810000) created
2013-04-06 21:38:11,960 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-aggregator-plugin-5.2.0.jar (1364879814000) created
2013-04-06 21:38:11,975 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-api-5.2.0.jar (1364879704000) created
2013-04-06 21:38:11,990 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-core-plugin-5.2.0.jar (1364879814000) created
2013-04-06 21:38:12,010 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-inline-actions-plugin-5.2.0.jar (1364879814000) created
2013-04-06 21:38:12,021 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-jira-inline-actions-plugin-5.2.0.jar (1364879814000) created
2013-04-06 21:38:12,602 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-jira-plugin-5.2.0.jar (1364879810000) created
2013-04-06 21:38:12,621 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-spi-5.2.0.jar (1364879704000) created
2013-04-06 21:38:12,659 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/streams-thirdparty-plugin-5.2.0.jar (1364879814000) created
2013-04-06 21:38:12,704 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /home/jira/plugins/.bundled-plugins/workflow-designer-plugin-3.0.0-m14.jar (1364879810000) created
2013-04-06 21:38:50,720 Spring executor 9 WARN [org.springframework.beans.TypeConverterDelegate] PropertyEditor [com.sun.beans.editors.EnumEditor] found through deprecated global PropertyEditorManager fallback - consider using a more isolated form of registration, e.g. on the BeanWrapper/BeanFactory!
2013-04-06 21:39:02,321 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.streams.core, com.atlassian.sal.jira, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, crowd-rest-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.gadgets.publisher, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 59 seconds remaining
2013-04-06 21:39:03,354 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.lookandfeel, com.atlassian.streams.core, com.atlassian.sal.jira, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, crowd-rest-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.gadgets.publisher, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 58 seconds remaining
2013-04-06 21:39:04,354 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.streams.core, com.atlassian.sal.jira, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.plugins.atlassian-custom-apps-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 57 seconds remaining
2013-04-06 21:39:05,355 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.streams.core, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 56 seconds remaining
2013-04-06 21:39:06,356 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 55 seconds remaining
2013-04-06 21:39:07,754 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 54 seconds remaining
2013-04-06 21:39:08,755 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 53 seconds remaining
2013-04-06 21:39:09,756 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.activeobjects.activeobjects-plugin], 52 seconds remaining
2013-04-06 21:39:10,757 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 51 seconds remaining
2013-04-06 21:39:11,757 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 50 seconds remaining
2013-04-06 21:39:12,762 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.administration.atlassian-admin-quicksearch-jira, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-nav-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 49 seconds remaining
2013-04-06 21:39:13,763 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 48 seconds remaining
2013-04-06 21:39:14,763 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 47 seconds remaining
2013-04-06 21:39:15,764 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 46 seconds remaining
2013-04-06 21:39:18,822 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.jira.rest, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 43 seconds remaining
2013-04-06 21:39:19,823 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.gadgets.directory, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 42 seconds remaining
2013-04-06 21:39:19,845 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.dashboard, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:19,970 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.dashboard], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)] (from bean [&renderedGadgetUriBuilder]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.dashboard' has timed out
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
2013-04-06 21:39:20,147 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2013-04-06 21:39:20,150 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-06 21:39:20,150 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&renderedGadgetUriBuilder' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)
2013-04-06 21:39:20,151 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-06 21:39:20,152 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.dashboard
2013-04-06 21:39:20,166 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.dashboard, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:20,385 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:20,386 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.embedded], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)] (from bean [&securityTokenFactory]), Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.embedded' has timed out
2013-04-06 21:39:20,431 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&securityTokenFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)
2013-04-06 21:39:20,431 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2013-04-06 21:39:20,431 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.embedded
2013-04-06 21:39:20,461 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:20,677 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:20,682 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.directory], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.directory' has timed out
2013-04-06 21:39:20,711 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.directory' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-06 21:39:20,711 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.directory
2013-04-06 21:39:20,715 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:20,778 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:20,779 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.oauth.serviceprovider], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.oauth.serviceprovider' has timed out
2013-04-06 21:39:20,807 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2013-04-06 21:39:20,807 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-06 21:39:20,807 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.oauth.serviceprovider
2013-04-06 21:39:20,812 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:20,824 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 41 seconds remaining
2013-04-06 21:39:21,886 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 40 seconds remaining
2013-04-06 21:39:22,886 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 39 seconds remaining
2013-04-06 21:39:23,159 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:23,166 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.collector.plugin.jira-issue-collector-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' has timed out
2013-04-06 21:39:23,222 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-06 21:39:23,223 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-06 21:39:23,223 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.collector.plugin.jira-issue-collector-plugin
2013-04-06 21:39:23,235 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:23,887 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 38 seconds remaining
2013-04-06 21:39:24,966 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 37 seconds remaining
2013-04-06 21:39:27,481 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.mywork.mywork-common-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.jirafisheyeplugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.jira.gadgets, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 34 seconds remaining
2013-04-06 21:39:27,482 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:27,523 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.gadgets-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.dashboard.DashboardService)] (from bean [&dashboardService]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.gadgets-plugin' has timed out
2013-04-06 21:39:27,535 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-06 21:39:27,535 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&dashboardService' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.dashboard.DashboardService)
2013-04-06 21:39:27,535 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2013-04-06 21:39:27,535 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.jira.gadgets
2013-04-06 21:39:27,540 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:28,482 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 33 seconds remaining
2013-04-06 21:39:29,506 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.jira.welcome.jira-welcome-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], 32 seconds remaining
2013-04-06 21:39:30,507 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 31 seconds remaining
2013-04-06 21:39:31,507 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.gadgets.opensocial, com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 30 seconds remaining
2013-04-06 21:39:32,508 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 29 seconds remaining
2013-04-06 21:39:33,508 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 28 seconds remaining
2013-04-06 21:39:34,510 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 27 seconds remaining
2013-04-06 21:39:35,511 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.labs.remoteapps-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 26 seconds remaining
2013-04-06 21:39:36,511 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 25 seconds remaining
2013-04-06 21:39:37,512 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 24 seconds remaining
2013-04-06 21:39:38,512 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 23 seconds remaining
2013-04-06 21:39:39,514 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 22 seconds remaining
2013-04-06 21:39:40,514 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 21 seconds remaining
2013-04-06 21:39:41,515 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 20 seconds remaining
2013-04-06 21:39:42,516 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 19 seconds remaining
2013-04-06 21:39:43,516 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 18 seconds remaining
2013-04-06 21:39:44,518 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 17 seconds remaining
2013-04-06 21:39:45,519 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams, com.atlassian.streams.actions, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 16 seconds remaining
2013-04-06 21:39:46,149 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:46,153 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.inline-actions-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)] (from bean [&streamsLocaleProvider])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out
2013-04-06 21:39:46,158 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsLocaleProvider' for plugin 'com.atlassian.streams.actions' with filter (objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)
2013-04-06 21:39:46,159 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.actions
2013-04-06 21:39:46,163 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:46,343 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:46,345 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.aggregator-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)] (from bean [&formatPreferenceProvider]), Dependency on [(objectClass=com.atlassian.streams.spi.EntityResolver)] (from bean [&entityResolvers])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out
2013-04-06 21:39:46,350 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&formatPreferenceProvider' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)
2013-04-06 21:39:46,350 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityResolvers' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.EntityResolver)
2013-04-06 21:39:46,351 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams
2013-04-06 21:39:46,355 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:46,521 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 15 seconds remaining
2013-04-06 21:39:47,521 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 14 seconds remaining
2013-04-06 21:39:48,523 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 13 seconds remaining
2013-04-06 21:39:49,525 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams.streams-jira-plugin], 12 seconds remaining
2013-04-06 21:39:49,729 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:49,732 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.jira-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out
2013-04-06 21:39:49,737 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2013-04-06 21:39:49,737 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-jira-plugin
2013-04-06 21:39:49,741 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:49,828 Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2013-04-06 21:39:49,830 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.thirdparty-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.UserProfileAccessor)] (from bean [&userProfileAccessor])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out
2013-04-06 21:39:49,835 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userProfileAccessor' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.spi.UserProfileAccessor)
2013-04-06 21:39:49,836 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-thirdparty-plugin
2013-04-06 21:39:49,839 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml))
2013-04-06 21:39:51,971 localhost-startStop-1 INFO [jira.plugins.monitor.MonitoringScheduler] Scheduling metrics collector to run every 10000ms...
2013-04-06 21:39:51,984 localhost-startStop-1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: /home/jira/monitor/ConnectionPoolGraph.rrd4j
2013-04-06 21:39:53,317 localhost-startStop-1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: /home/jira/monitor/DatabaseReadWritesGraph.rrd4j
2013-04-06 21:39:53,326 localhost-startStop-1 INFO [jira.plugins.monitor.MonitorLauncher] Started JIRA monitoring
2013-04-06 21:39:56,704 localhost-startStop-1 INFO [atlassian.plugin.loaders.ScanningPluginLoader] No plugins found to be deployed
2013-04-06 21:39:56,738 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Plugin system started in 0:02:42.807
2013-04-06 21:39:56,825 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Plugin System Started _________________
2013-04-06 21:39:57,376 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /home/jira/dbconfig.xml
2013-04-06 21:39:57,445 localhost-startStop-1 INFO [jira.instrumentation.external.DatabaseExternalGauges] Installing DBCP monitoring instruments: DatabaseExternalGauges.JiraDbcpInstruments[instruments=[DBCP_MAX, DBCP_ACTIVE, DBCP_IDLE],objectName=com.atlassian.jira:name=BasicDataSource]
2013-04-06 21:39:58,574 localhost-startStop-1 INFO [atlassian.jira.upgrade.ConsistencyCheckImpl] Checking JIRA consistency
2013-04-06 21:39:58,611 localhost-startStop-1 INFO [atlassian.jira.upgrade.ConsistencyCheckImpl] The Server ID for this JIRA instance is: [B6DL-3IM3-OWCR-283I]
2013-04-06 21:39:59,515 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Core Application Properties _____________
Version : 5.2.10
Build # : 853
Build Date : Tue Apr 02 00:00:00 CEST 2013
Installation Type : Standalone
Server ID : B6DL-3IM3-OWCR-283I
Base URL : not set
Default Language : français (France)
External User Management : OFF
___ Application Properties _________________
AO_4AEACD_# : 1
com.atlassian.activeobjects.admin.ActiveObjectsPluginToTablesMapping : null
jira.ajax.autocomplete.issuepicker.enabled : true
jira.ajax.autocomplete.labelsuggestion.limit : 20
jira.ajax.autocomplete.limit : 20
jira.alertheader.visibility : private
jira.assignee.change.is.sent.to.both.parties : true
jira.attachment.allow.zip.support : true
jira.attachment.do.not.expand.as.zip.extensions.list : docx, docm, dotx, dotm, xlsx, xlsm, xltx, xltm, xlsb, xlam, pptx, pptm, potx, potm, ppam, ppsx, ppsm, sldx, sldm, thmx, odt, odp, ods, odg, odb, odf, ott, otp, ots, otg, odm, sxw, stw, sxc, stc, sxi, sti, sxd, std, sxg
jira.attachment.download.mime.sniffing.workaround : workaround
jira.attachment.number.of.zip.entries : 30
jira.autoexport : true
jira.avatar.megapixels : 10
jira.browser.unsupported.warnings.disabled : false
jira.bulk.edit.limit.issue.count : 1000
jira.chart.days.previous.limit.daily : 300
jira.chart.days.previous.limit.hourly : 10
jira.chart.days.previous.limit.monthly : 7500
jira.chart.days.previous.limit.quarterly : 22500
jira.chart.days.previous.limit.weekly : 1750
jira.chart.days.previous.limit.yearly : 36500
jira.clone.linktype.name : Cloners
jira.clone.prefix : CLONE -
jira.comment.level.visibility.groups : false
jira.dashboard.max.gadgets : 20
jira.databasequery.batch.size : 100
jira.date.picker.java.format : d/MMM/yy
jira.date.picker.javascript.format : %e/%b/%y
jira.date.time.picker.java.format : dd/MMM/yy h:mm a
jira.date.time.picker.javascript.format : %e/%b/%y %I:%M %p
jira.date.time.picker.use.iso8061 : false
jira.db.txns.disabled : false
jira.default.jndi.name : java:comp/env/jdbc/JiraDS
jira.disable.login.gadget : false
jira.disable.multipart.get.http.request : true
jira.email.fromheader.format : ${fullname} (JIRA)
jira.enabled.dark.features :
jira.export.fetchsize : -1
jira.exportimport.cleanxml : true
jira.home :
jira.i18n.include.meta-data : true
jira.i18n.language.index : english
jira.import.maxqueuesize : 100
jira.import.threads : 10
jira.index.background.batch.size : 1000
jira.index.batch.maxbuffereddocs : 300
jira.index.batch.maxmergedocs : 2147483647
jira.index.batch.mergefactor : 50
jira.index.interactive.maxbuffereddocs : 300
jira.index.interactive.maxmergedocs : 2147483647
jira.index.interactive.mergefactor : 4
jira.index.issue.maxqueuesize : 1000
jira.index.issue.minbatchsize : 50
jira.index.issue.threads : 10
jira.index.lock.waittime : 30000
jira.index.max.reindexes : 2147483647
jira.index.maxfieldlength : 10000
jira.index.mergepolicy.expungedeletespctallowed : 10
jira.index.mergepolicy.floorsegmentmb : 2
jira.index.mergepolicy.maxmergeatonce : 10
jira.index.mergepolicy.maxmergeatonceexplicit : 30
jira.index.mergepolicy.maxmergedsegmentmb : 512
jira.index.mergepolicy.nocfspct : 10
jira.index.mergepolicy.segmentspertier : 10
jira.index.mergepolicy.usecompoundfile : true
jira.index.sharedentity.maxqueuesize : 1000
jira.index.sharedentity.minbatchsize : 50
jira.index.sharedentity.threads : 10
jira.index.update.bulk.optimization : 400
jira.issue.actions.order : asc
jira.issueindex.fetch.size : 200
jira.issuenav.criteria.autoupdate : true
jira.lf.application.id : jira
jira.lf.date.complete : dd/MMM/yy h:mm a
jira.lf.date.day : EEEE h:mm a
jira.lf.date.dmy : dd/MMM/yy
jira.lf.date.relativize : true
jira.lf.date.time : h:mm a
jira.lf.favicon.hires.url : /images/64jira.png
jira.lf.favicon.url : /favicon.ico
jira.lf.gadget.color1 : #369
jira.lf.gadget.color2 : #900925
jira.lf.gadget.color3 : #d94625
jira.lf.gadget.color4 : #346006
jira.lf.gadget.color5 : #003366
jira.lf.gadget.color6 : #411E66
jira.lf.gadget.color7 : #bbb
jira.lf.hero.button.base.bg.colour : #3b7fc4
jira.lf.hero.button.text.colour : #ffffff
jira.lf.logo.height : 30
jira.lf.logo.show.application.title : false
jira.lf.logo.url : /images/icon-jira-logo.png
jira.lf.logo.width : 57
jira.lf.menu.bgcolour : #326ca6
jira.lf.menu.separator : #f0f0f0
jira.lf.menu.textcolour : #ffffff
jira.lf.text.activelinkcolour : #326ca6
jira.lf.text.headingcolour : #292929
jira.lf.text.linkcolour : #326ca6
jira.lf.top.bgcolour : #205081
jira.lf.top.hilightcolour : #296CA3
jira.lf.top.separator.bgcolor : #2E3D54
jira.lf.top.textcolour : #ffffff
jira.lf.top.texthilightcolour : #f0f0f0
jira.mail.fetch.disabled : false
jira.mail.send.disabled : false
jira.max.AdminPage.history.items : 5
jira.max.Issue.history.items : 50
jira.max.JQLQuery.history.items : 10
jira.max.history.items : 10
jira.max.issue.filter.dropdown.items : 10
jira.max.issue.history.dropdown.items : 6
jira.option.allowcookies : true
jira.option.allowthumbnails : true
jira.option.emailvisible : show
jira.option.ignore.url.with.key : true
jira.option.logoutconfirm : never
jira.option.web.usegzip : true
jira.project.summary.max.issues : 3
jira.projectkey.description : admin.projects.key.description
jira.projectkey.pattern : ([A-Z][A-Z]+)
jira.projectkey.reservedwords.list : PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7, COM8, COM9, CON, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, LPT9
jira.projectkey.warning : admin.errors.must.specify.unique.project.key
jira.releasenotes.default : Html
jira.releasenotes.templatenames : Html, Text
jira.releasenotes.templates : releasenotes-html.vm, releasenotes-text.vm
jira.schemes.comparison.max : 5
jira.screenshotapplet.enabled : true
jira.screenshotapplet.linux.enabled : false
jira.search.fullcontentview.pagebreaks : true
jira.search.maxclauses : 65000
jira.search.views.default.max : 1000
jira.search.views.max.limit : 1000
jira.search.views.max.unlimited.group :
jira.sendmail.recipient.batch.size : 100
jira.show.contact.administrators.form : false
jira.subscription.email.max.issues : 200
jira.table.cols.dashboard : issuetype, issuekey, summary, priority
jira.table.cols.subtasks : issuetype, status, assignee, progress
jira.table.cols.voted : issuetype, issuekey, summary, priority, status
jira.table.cols.watched : issuetype, issuekey, summary, priority, status
jira.table.gadget.max.rows : 50
jira.text.field.character.limit : 0
jira.thumbnail.maxheight : 200
jira.thumbnail.maxwidth : 200
jira.timetracking.copy.comment.to.work.desc.on.transition : true
jira.timetracking.days.per.week : 5
jira.timetracking.estimates.legacy.behaviour : true
jira.timetracking.format : pretty
jira.timetracking.hours.per.day : 8
jira.title : JIRA
jira.trustedapps.timeout.default : 10000
jira.trustedapps.urlmatch.default : /sr/jira.issueviews:searchrequest
/secure/RunPortlet
/rest
/rpc/soap
/plugins/servlet/streams
/plugins/servlet/applinks
jira.usermanagement.maxdisplaymembers : 200
jira.view.issue.links.sort.order : type, status, priority
jira.view.issue.show.quicksubtask.when.no.subtasks : false
jira.viewcvs.root.type : cvsroot
jira.webresource.flushcounter : 1
jira.webresource.superbatch.flushcounter : 1
jira.websudo.is.disabled : false
jira.websudo.timeout : 10
jira.xsrf.enabled : true
show.plugin.marketing.hints : true
user.default.share.private : true
user.issues.per.page : 50
user.keyboard.shortcuts.disabled : false
user.notifications.mimetype : html
user.notify.own.changes : false
user.show.actions.in.navigator : true
webwork.i18n.encoding : UTF-8
___ License Details ________________________
License Set : false
___ Database Statistics ____________________
Issues : 0
Projects : 0
Custom Fields : 0
Workflows : 0
Users : 0
Groups : 0
Attachments : 0
Comments : 0
___ Upgrade History ________________________
No upgrade information is available for this instance.
___ File Paths _____________________________
JIRA Home : /home/jira
Location of atlassian-jira.log : /home/jira/log/atlassian-jira.log
Index Path :
Attachment Path :
___ User Plugins ____________________________
Number : 0
___ System Plugins __________________________
Number : 98
ActiveObjects Plugin - OSGi Bundle : com.atlassian.activeobjects.activeobjects-plugin
Version : 0.19.16
Status : enabled
Vendor : Atlassian
Description : An OSGi bundle that provides a service that allows plugins to persist objects using the ActiveObjects framework
Apache HttpClient OSGi bundle : org.apache.httpcomponents.httpclient-4.0
Version : 4.0
Status : enabled
Vendor : Apache Software Foundation
Description : HttpComponents Client (OSGi bundle)
Apache HttpCore OSGi bundle : org.apache.httpcomponents.httpcore-4.0
Version : 4.0
Status : enabled
Description : HttpComponents Core (OSGi bundle)
Applinks Product Plugin : com.atlassian.applinks.applinks-plugin
Version : 3.10.4
Status : enabled
Vendor : Atlassian
Description : Plugin that facilitates discovery, connections and authentication with remote applications
Atlassian - Administration - Quick Search - JIRA : com.atlassian.administration.atlassian-admin-quicksearch-jira
Version : 1.1.1
Status : enabled
Vendor : Atlassian
Description : Administration Quick Search plugin for JIRA
Atlassian Bot Session Killer : com.atlassian.labs.atlassian-bot-killer
Version : 1.7.2.1
Status : enabled
Vendor : Atlassian
Description : This will remove unwanted http sessions for requests that exhibit Bot like behaviour. That is they make a single request, don't preserve cookies and never call again.
Atlassian Custom Apps Plugin : com.atlassian.plugins.atlassian-custom-apps-plugin
Version : 1.15
Status : enabled
Vendor : Atlassian
Description : Create and edit custom applications shown in the application switcher.
Atlassian Embedded Crowd - Administration Plugin : com.atlassian.crowd.embedded.admin
Version : 1.4.5
Status : enabled
Vendor : Atlassian
Description : Provides the administration of local and remote user directories.
Atlassian Gadgets OAuth Service Provider Plugin : com.atlassian.gadgets.oauth.serviceprovider
Version : 3.2.0-m2-1
Status : disabled
Vendor : Atlassian
Description : Plugin that makes OAuth Service Providers Gadget aware.
Atlassian JIRA - Admin Helper Plugin : com.atlassian.jira.plugins.jira-admin-helper-plugin
Version : 1.6
Status : enabled
Vendor : Atlassian Pty Ltd
Description : The Admin Helper plugin helps admins determine visibility of custom fields and also provides reasons for why a user does not have certain permissions on an issue or does not receive notifications for that issue.
Atlassian JIRA - Plugins - Admin Summary Component : com.atlassian.jira.jira-admin-summary-plugin
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Supplies Content to the JIRA Administration Summary Page
Atlassian JIRA - Plugins - Application Properties : com.atlassian.jira.jira-application-properties-plugin
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides advanced application properties configuration
Atlassian JIRA - Plugins - Closure Template Renderer : com.atlassian.jira.jira-soy-plugin
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides renderer for Closure templates
Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin : com.atlassian.jira.jira-issue-link-applinks-common-plugin
Version : 5.2.10
Status : enabled
Vendor : ${project.organization.name}
Description : Provides the common utilities for AppLinks based issue link plugins
Atlassian JIRA - Plugins - Confluence Link : com.atlassian.jira.jira-issue-link-confluence-plugin
Version : 5.2.10
Status : enabled
Description : Provides creation and rendering of issue links to Confluence pages
Atlassian JIRA - Plugins - Gadgets Plugin : com.atlassian.jira.gadgets
Version : 5.2.10
Status : disabled
Vendor : Atlassian
Description : Provides Gadgets and REST endpoints bundled with JIRA
Atlassian JIRA - Plugins - Header Plugin : com.atlassian.jira.jira-header-plugin
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides markup/styles/behaviour/plugin points for the header
Atlassian JIRA - Plugins - Invite User : com.atlassian.jira.jira-invite-user-plugin
Version : 1.6
Status : enabled
Vendor : Atlassian
Description : Allows administrators to invite users to sign up for an account
Atlassian JIRA - Plugins - Issue Navigation : com.atlassian.jira.jira-issue-nav-plugin
Version : 1.1.25.21
Status : enabled
Vendor : Atlassian
Description : Provides issue search and navigation
Atlassian JIRA - Plugins - Issue Web Link : com.atlassian.jira.jira-issue-link-web-plugin
Version : 5.2.10
Status : enabled
Description : Provides creation and rendering of issue links to web pages
Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin : com.atlassian.jira.lookandfeel
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides logo upload capabilities
Atlassian JIRA - Plugins - Mail Plugin : com.atlassian.jira.jira-mail-plugin
Version : 5.2.21.1
Status : enabled
Vendor : Atlassian
Description : Handles incoming and outgoing mail
Atlassian JIRA - Plugins - My JIRA Home : com.atlassian.jira.jira-my-home-plugin
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Lets the user pick a landing page.
Atlassian JIRA - Plugins - OAuth Consumer SPI : com.atlassian.jira.oauth.consumer
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides the Consumer SPI implementation required for OAuth in JIRA.
Atlassian JIRA - Plugins - OAuth Service Provider SPI : com.atlassian.jira.oauth.serviceprovider
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides the OAuth Service Provider SPI implementation required for OAuth in JIRA.
Atlassian JIRA - Plugins - Project Config Plugin : com.atlassian.jira.jira-project-config-plugin
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides easier project administration with JIRA
Atlassian JIRA - Plugins - Quick Edit Plugin : com.atlassian.jira.jira-quick-edit-plugin
Version : 1.0.54
Status : enabled
Vendor : Atlassian
Description : This is the com.atlassian.jira:jira-quick-edit-plugin plugin for Atlassian JIRA.
Atlassian JIRA - Plugins - REST Plugin : com.atlassian.jira.rest
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Provides a REST interface for JIRA
Atlassian JIRA - Plugins - Remote JIRA Link : com.atlassian.jira.jira-issue-link-remote-jira-plugin
Version : 5.2.10
Status : enabled
Description : Provides creation and rendering of links to local and remote JIRA issues
Atlassian JIRA - Plugins - SAL Plugin : com.atlassian.sal.jira
Version : 5.2.10
Status : enabled
Vendor : Atlassian Software Systems
Description : JIRA implementation of the Shared Application Access Layer (SAL)
Atlassian JIRA - Plugins - Share Content Component : com.atlassian.jira.jira-share-plugin
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : Allows users to share issue and searches
Atlassian JIRA - Plugins - User Profile Plugin : com.atlassian.jira.jira-user-profile-plugin
Version : 1.1.0
Status : enabled
Vendor : Atlassian
Description : Plugin uses web-panels to encapsulate details and preferences modules from user profile page.
Atlassian JIRA - Plugins - View Issue Panels : com.atlassian.jira.jira-view-issue-plugin
Version : 5.2.10
Status : enabled
Description : Provides WebPanels for the View Issue Page
Atlassian Navigation Links Plugin : com.atlassian.plugins.atlassian-nav-links-plugin
Version : 1.3.16
Status : enabled
Vendor : Atlassian
Description : Capabilities and Navigation API client and server implementation
Atlassian OAuth Admin Plugin : com.atlassian.oauth.admin
Version : 1.6.1
Status : enabled
Vendor : Atlassian
Description : Plugin that provides a single tabbed view for administering OAuth consumers and service provider information.
Atlassian OAuth Consumer Plugin : com.atlassian.oauth.consumer
Version : 1.6.1
Status : enabled
Vendor : Atlassian
Description : Plugin that makes it possible for applications to become Consumers.
Atlassian OAuth Consumer SPI : com.atlassian.oauth.atlassian-oauth-consumer-spi-1.6.1
Version : 1.6.1
Status : enabled
Vendor : Atlassian
Description : Consumer SPIs to allow applications to provide custom implementations of storing token and consumer info
Atlassian OAuth Service Provider Plugin : com.atlassian.oauth.serviceprovider
Version : 1.6.1
Status : enabled
Vendor : Atlassian
Description : Plugin that makes it possible for applications to become Service Providers.
Atlassian OAuth Service Provider SPI : com.atlassian.oauth.atlassian-oauth-service-provider-spi-1.6.1
Version : 1.6.1
Status : enabled
Vendor : Atlassian
Description : Service Provider SPIs to allow applications to provide custom implementations of storing token consumer info
Atlassian REST - Module Types : com.atlassian.plugins.rest.atlassian-rest-module
Version : 2.7.1
Status : enabled
Vendor : Atlassian
Description : A plugin that contains REST module types
Atlassian Remote Apps - Plugin : com.atlassian.labs.remoteapps-plugin
Version : 0.4.518.3
Status : enabled
Vendor : Atlassian
Description : This is the parent for the Atlassian Remote Apps project
Atlassian Soy Templates - Plugin : com.atlassian.soy.soy-template-plugin
Version : 1.1.3
Status : enabled
Vendor : Atlassian
Description : Base POM for Atlassian projects
Atlassian Template Renderer API : com.atlassian.templaterenderer.api
Version : 1.4.2.2
Status : enabled
Vendor : Atlassian
Description : API and plugins for easily rendering content from different template engines.
Atlassian Template Renderer Velocity 1.6 Plugin : com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin
Version : 1.4.2.2
Status : enabled
Vendor : Atlassian
Atlassian UI Plugin : com.atlassian.auiplugin
Version : 5.0-m10
Status : enabled
Vendor : Atlassian
Description : An Atlassian plugin that contains the core javascript files used in Atlassian products.
Atlassian Universal Plugin Manager Plugin : com.atlassian.upm.atlassian-universal-plugin-manager-plugin
Version : 2.7.10
Status : enabled
Vendor : Atlassian
Description : This is the plugin that provides the Atlassian Universal Plugin Manager.
Crowd REST API : crowd-rest-application-management
Version : 1.0
Status : enabled
Description : Crowd REST API - Application Management
Crowd REST API : crowd-rest-plugin
Version : 1.0
Status : enabled
Crowd System Password Encoders : crowd.system.passwordencoders
Version : 1.0
Status : enabled
Description : Crowd Password Encoders shipped with Crowd
Embedded Gadgets Plugin : com.atlassian.gadgets.embedded
Status : disabled
Vendor : Atlassian
Description : Plugin which allows gadgets to be embedded in pages
English (United Kingdom) Language Pack : com.atlassian.jira.jira-languages.en_UK
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : This plugin contains translations the core keys in JIRA for English (United Kingdom).
English (United States) Language Pack : com.atlassian.jira.jira-languages.en_US
Version : 5.2.10
Status : enabled
Vendor : Atlassian
Description : This plugin contains translations the core keys in JIRA for English (United States).
FishEye Plugin : com.atlassian.jirafisheyeplugin
Version : 5.2.9
Status : enabled
Description : JIRA Fisheye Plugin
Gadget Dashboard Plugin : com.atlassian.gadgets.dashboard
Status : disabled
Vendor : Atlassian
Description : Plugin which renders a dashboard of gadgets
Gadget Directory Plugin : com.atlassian.gadgets.directory
Status : disabled
Vendor : Atlassian
Description : Plugin which renders a directory of gadgets
Gadget Spec Publisher Plugin : com.atlassian.gadgets.publisher
Status : enabled
Vendor : Atlassian
Description : Plugin which provides a way to publish gadget specs found in plugins
HipChat : com.atlassian.labs.hipchat.hipchat-for-jira-plugin
Version : 1.1.13
Status : enabled
Vendor : Atlassian
Description : This is the HipChat plugin for JIRA.
ICU4J : com.atlassian.bundles.icu4j-3.8.0.1
Version : 3.8.0.1
Status : enabled
Description : ICU4J as an OSGi bundle
JDOM DOM Processor : com.springsource.org.jdom-1.0.0
Version : 1.0.0
Status : enabled
Vendor : SpringSource
Description :
JIRA Active Objects SPI implementation : com.atlassian.activeobjects.jira.spi
Version : 0.19.16
Status : enabled
Description : A plugin that provides the DataSourceProvider service
JIRA Activity Stream Plugin : com.atlassian.streams.streams-jira-plugin
Version : 5.2.0
Status : disabled
Vendor : Atlassian
Description : Lists recent activity in a single project, or in all projects.
JIRA Bamboo Plugin : com.atlassian.jira.plugin.ext.bamboo
Version : 5.2.1
Status : enabled
Vendor : Atlassian Software Systems Pty Ltd
Description : Allows you to see builds and telemetry from a remote Bamboo server
JIRA Base URL Plugin : com.atlassian.jira.jira-baseurl-plugin
Version : 1.9
Status : enabled
Vendor : Atlassian
Description : Detects incorrectly-set base URLs in JIRA.
JIRA French (France) Language Pack : tac.jira.languages.fr_FR
Version : 5.2.8-v2r2373-2013-03-15
Status : enabled
Vendor : Atlassian Community
Description : This plugin contains translations for fr_FR
JIRA German (Germany) Language Pack : tac.jira.languages.de_DE
Version : 5.2.8-v2r5721-2013-03-15
Status : enabled
Description : This plugin contains translations for de_DE
JIRA Importers Plugin (JIM) : com.atlassian.jira.plugins.jira-importers-plugin
Version : 5.0.3
Status : enabled
Vendor : Atlassian
Description : A plugin (originally part of JIRA 4.2 and older) which provides capability to import to JIRA issues from 3rd party issue trackers: Bugzilla, FogBugz and Mantis.
JIRA Issue Collector Plugin : com.atlassian.jira.collector.plugin.jira-issue-collector-plugin
Version : 1.2.9
Status : disabled
Vendor : Atlassian
Description : This plugin provides the ability to create issues from remote applications
JIRA JSON-RPC Plugin : com.atlassian.jira.rpc.jira-json-rpc-plugin
Version : 1.0.4
Status : enabled
Description : Exposes JIRA SOAP services using JSON-RPC
JIRA Japanese (Japan) Language Pack : tac.jira.languages.ja_JP
Version : 5.2.8-v2r15554-2013-03-18
Status : enabled
Description : This plugin contains translations for ja_JP
JIRA Monitoring Plugin : com.atlassian.jira.jira-monitoring-plugin
Version : 05.5.4
Status : enabled
Vendor : Atlassian
Description : Records and exposes JIRA key performance metrics
JIRA Spanish (Spain) Language Pack : tac.jira.languages.es_ES
Version : 5.2.8-v2r12795-2013-03-15
Status : enabled
Description : This plugin contains translations for es_ES
JIRA Streams Inline Actions Plugin : com.atlassian.streams.jira.inlineactions
Version : 5.2.0
Status : enabled
Description : JIRA Streams Inline Actions Plugin
JIRA Time Zone Detection plugin : com.atlassian.jira.jira-tzdetect-plugin
Version : 1.6
Status : enabled
Vendor : Atlassian
Description : Performs client-side time zone detection for JIRA.
JIRA Usage Hints : jira.usage.hints
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This library includes the web fragments for JIRA usage hints displayed on issue operation dialogs. It should never be disabled.
JIRA WebHooks Plugin : com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin
Version : 1.0.8
Status : enabled
Vendor : Atlassian
Description : This plugin provides the ability to register Web Hooks for events in JIRA
JIRA Welcome Plugin : com.atlassian.jira.welcome.jira-welcome-plugin
Version : 1.1.34
Status : enabled
Vendor : Atlassian
Description : Displays a welcome dialog for first-time usage of JIRA, as well as a whats new dialog for users just having upgraded to this version of JIRA.
JIRA iCalendar Plugin : com.atlassian.jira.extra.jira-ical-feed
Version : 1.0.12
Status : enabled
Vendor : Atlassian
Description : Provides an iCal feed of JIRA issues and versions
JQL Functions : jira.jql.function
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This plugin implements a JQL function in JIRA.
JSON Library : com.atlassian.bundles.json-20070829.0.0.1
Version : 20070829.0.0.1
Status : enabled
Description : Library for manipulating JSON
Keyboard Shortcuts Plugin : jira.keyboard.shortcuts
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : A plugin that defines a number of keyboard shortcuts.
Neko HTML : com.atlassian.bundles.nekohtml-1.9.12.1
Version : 1.9.12.1
Status : enabled
Description : Neko HTML library as an OSGi bundle
Notifications and Tasks - Common Plugin : com.atlassian.mywork.mywork-common-plugin
Version : 1.1.9
Status : enabled
Vendor : Atlassian
Description : Provides Common Services to Notifications and Tasks
Notifications and Tasks - JIRA Provider Plugin : com.atlassian.mywork.mywork-jira-provider-plugin
Version : 1.1.9
Status : enabled
Vendor : Atlassian
Description : Generates Notifications and Tasks from JIRA
Opensocial Plugin : com.atlassian.gadgets.opensocial
Status : enabled
Vendor : Atlassian
Description : Plugin for OpenSocial API Support and Gadget Rendering
ROME, RSS and atOM utilitiEs for Java : rome.rome-1.0
Version : 1.0
Status : enabled
Vendor : Sun Microsystems
Description : All Roads Lead to ROME. ROME is a set of Atom/RSS Java utilities that make iteasy to work in Java with most syndication formats. Today it accepts all flavors of RSS(0.90, 0.91, 0.92, 0.93, 0.94, 1.0 and 2.0), Atom 0.3 and Atom 1.0 feeds. Rome includesa set of parsers and generators for the various flavors of feeds, as well as convertersto convert from one format to another. The parsers can give you back Java objects thatare either specific for the format you want to work with, or a generic normalizedSyndFeed object that lets you work on with the data without bothering about theunderlying format.
ROME: RSS/Atom syndication and publishing tools : com.springsource.com.sun.syndication-0.9.0
Version : 0.9.0
Status : enabled
Description :
RPC JIRA Plugin : com.atlassian.jira.ext.rpc
Version : 5.1.3
Status : enabled
Vendor : Atlassian
Description : The standard JIRA RPC services, both SOAP and XML-RPC.
Streams API : com.atlassian.streams.streams-api-5.2.0
Version : 5.2.0
Status : enabled
Vendor : Atlassian
Streams Core Plugin : com.atlassian.streams.core
Version : 5.2.0
Status : enabled
Description : Streams Core Plugin
Streams Inline Actions Plugin : com.atlassian.streams.actions
Version : 5.2.0
Status : disabled
Description : Streams Inline Actions Plugin
Streams Plugin : com.atlassian.streams
Version : 5.2.0
Status : disabled
Description : Streams Plugin
Streams SPI : com.atlassian.streams.streams-spi-5.2.0
Version : 5.2.0
Status : enabled
Vendor : Atlassian
Streams Third Party Provider Plugin : com.atlassian.streams.streams-thirdparty-plugin
Version : 5.2.0
Status : disabled
Vendor : Atlassian
Support Tools Plugin : com.atlassian.support.stp
Version : 3.0.11
Status : enabled
Vendor : Atlassian Support
Description : This is the Support Tools Plugin, developed to help Atlassian customers with our products.
User Format : jira.user.format
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This plugin renders a user in JIRA.
User Profile Panels : jira.user.profile.panels
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This library includes the panels included on the user profile page.
Workflow Designer Plugin : com.atlassian.jira.plugins.jira-workflow-designer
Version : 3.0.0-m14
Status : enabled
Vendor : Atlassian
Description : The visual way to edit JIRA Workflows.
jira-help-tips : com.atlassian.plugins.helptips.jira-help-tips
Version : 0.29
Status : enabled
Vendor : Atlassian
Description : Common way to display help tips in the UI of JIRA.
___ Listeners ______________________________
Instance Count : 2
Mail Listener : com.atlassian.jira.event.listeners.mail.MailListener
Issue Assignment Listener : com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener
___ Services _______________________________
Instance Count : 1
Mail Queue Service : com.atlassian.jira.service.services.mail.MailQueueService
Service Delay : 60000ms
___ Trusted Applications ___________________
Instance Count : 0
___ Java Class Paths _______________________
sun.boot.class.path : /usr/lib/jvm/java-7-oracle/jre/lib/resources.jar:
/usr/lib/jvm/java-7-oracle/jre/lib/rt.jar:
/usr/lib/jvm/java-7-oracle/jre/lib/sunrsasign.jar:
/usr/lib/jvm/java-7-oracle/jre/lib/jsse.jar:
/usr/lib/jvm/java-7-oracle/jre/lib/jce.jar:
/usr/lib/jvm/java-7-oracle/jre/lib/charsets.jar:
/usr/lib/jvm/java-7-oracle/jre/lib/jfr.jar:
/usr/lib/jvm/java-7-oracle/jre/classes
java.library.path : /usr/java/packages/lib/amd64:
/usr/lib64:
/lib64:
/lib:
/usr/lib
java.endorsed.dirs : /opt/atlassian/deployed/jira/endorsed
java.ext.dirs : /usr/lib/jvm/java-7-oracle/jre/lib/ext:
/usr/java/packages/lib/ext
java.class.path : /opt/atlassian/deployed/jira/bin/bootstrap.jar:
/opt/atlassian/deployed/jira/bin/tomcat-juli.jar
2013-04-06 21:39:59,538 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
JIRA 5.2.10 build: 853 started. You can now access JIRA through your web browser.
2013-04-06 21:39:59,724 localhost-startStop-1 FATAL [atlassian.jira.startup.JiraStartupLogger]
The following plugins are required by JIRA, but have not been started: Embedded Gadgets Plugin (com.atlassian.gadgets.embedded), Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard), Gadget Directory Plugin (com.atlassian.gadgets.directory), Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
2013-04-06 21:39:59,732 localhost-startStop-1 FATAL [atlassian.jira.upgrade.UpgradeLauncher] Skipping, JIRA is locked.
2013-04-06 21:39:59,743 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler not started: JIRA startup checklist failed.
2013-04-06 21:40:00,346 localhost-startStop-1 ERROR [jira.web.dispatcher.JiraWebworkActionDispatcher]
JIRA startup failed, JIRA has been locked.
avr. 06, 2013 9:40:06 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
avr. 06, 2013 9:40:06 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 225670 ms
2013-04-06 21:40:11,112 Modification Check:thread-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Modifications ___________________________
Modified Files : jira-application.properties
Removed Files : None
5 votes
Christophe Gravier
Found the solution here : https://confluence.atlassian.com/display/CONFKB/Plugins+are+Disabled+at+Startup+and+Various+Timeout+Errors+Appear+in+the+Logs+After+Startup
And especially : "Add the JVM parameter -Datlassian.plugins.enable.wait=300. "
Malachi Burke June 5, 2013
This is a must for running on a slower machine. Thank you for this, fixed it for me!
rushdjava
August 23, 2013
worked great for me - using a medium Amazon Linux AMI (1.7gb RAM) it needed the extra time
