Friday question - problem entering comments
Tom Lister
Hi
This has been driving me nuts for months but I haven't had time to address it.
I can't type Jira into Jira !!!
When typing the word Jira it won't let me type a space and move on. I have to type Jiraa and then go back and remove the last character.
Can't remember when it started happening but a while back.
Anyone out there seen this before.
It could be a Safari issue. (That is rapidly becoming a browser to avoid IMHO)
Linda Alvarez August 29, 2022
This has driven my nuts for a long time too.  I finally narrowed it down to a Safari-specific behavior and was then able to find the aforementioned bug report. This report lists a couple workarounds. Mine is to add a "." after Jira.like this,  and then after finishing my sentence I go back in and delete the dot.
Negin Nafari June 22, 2022
Hey Tom, there is a reported bug to the Atlassian support regarding this behavior.
https://jira.atlassian.com/browse/JRASERVER-73024
Alex Koxaras _Relational_
Works fine on my server instance. The only "problem" I see is the autocorrect from jira to Jira (it capitalizes the J).
I would definitely try this from a private window and from a different browser. I would also ask my colleagues if they face the same problem.
Alex
