×I need to create a Confluence page from JIRA. How does one get a JIRA workflow transition to pass arguments to a shell script or Confluence CLI (shell script preferred). Accepting return codes a bonus. Please advise. Thanks, Mikael.
Praising myself:
http://confluence.kepler-rominfo.com/display/JJUP20/system
Your postfunction is this:
string [] rets = system("/opt/scripts/myscript.sh param1 param2");
it returns system exit code, first 4k from output and error streams.
Hi Mikael,
We believe that to achieve this requirement, the JIRA instance need to be customised or a plugin need to be developed. Since both customization and development related query is beyond the scope of our support, we strongly recommend you to create a query in https://answers.atlassian.com/ .
Do let us know if you have any other query.
Janet
Janet,
Thanks for your investigation into my question and your suggestions. Neither customizing my JIRA instance or creating a plugin is within the scope of my project. As an alternate approach, I am thinking of creating a custom hidden field "Create Confluence Page" that is a yes/no flag, that when at a particular workflow transition is triggered, the field is flagged as yes. Then I can use JIRA CLI to query for all issues with that field and use Confluence CLI to create a release page for all ones flagged as yes. After the page is created, the flag is set to no.
Please advise on how to create a custom field that is a) hidden and b) is automatically flagged during a workflow transition.
Mikael
Mikael,
My research on this issue has revealed that post-functions cannot be applied to custom fields at this time. You may find that some of the experts at Answers or possibly a plugin might be of assistance with this issue.
More information related to custom fields can be found at this link
Let us know right away if there's anything we can do to assist you further.
Thanks!
John Garcia
Atlassian Support - SF
Janet and John,
Thanks for your research and suggestions. I will check out Workflow Plugin Modules
(https://developer.atlassian.com/display/JIRADEV/Workflow+Plugin+Modules) and Applying post functions to transitions (https://confluence.atlassian.com/display/JIRA050/Configuring+Workflow) to see if they have what I need as a solution.
Mikael
You'll need to write a workflow post-function that makes the calls you need.
I'd actually start with Jamie's script runner ( https://studio.plugins.atlassian.com/wiki/display/GRV/Script+Runner ), as that gives you a lot of flexibility.
On the return code side, I think I'd shy away from that directly because you'll end up with users hanging around waiting for a response when they've done something simple. But you can do it.
