General advices how to fix troubles in JIRA
Vasiliy Zverev
February 10, 2016
Hi everybody.
Because there are some general advices to fix troubles I decided to collect it all at one place.
  1. Try to do integrity check: admin panel => system => integrity check
  2. Try to do reindex: admin panel => system => advanced => reindexation
If it does not helps then you can get more information into atlassian-jira.log:
  • for server version you can get it <jira-home>/Appliication Data/JIRA/log
  • for cloud version you should make support request to get it
Rahul Aich [Nagra]
February 10, 2016
I dont think you can generalise this with a series of steps. It can vary.
From my experience, i would go to the logs first and see whats happening. I would then find the error message or the find out the behavior and go to google and see if anyone else has seen this issue.
I would then log a question on answers. If the issue is critical i would log a support ticket.
But then this is my approach, it can vary from person to person.
Rahul
