Hello everybody,
is it possible to generate automatically issues while using a special kind of project blueprint.
E.g. we have always the same 70 steps (issues), which are necessary for our product development team.
Would be very helpfully for me if anybody has an answer!
Greets
Alex
Hello Alexander,
two different approaches:
1.) Copy a project-templates including the issues
Script Runner provides a build in script called "Copy Project". If you copy a project that has already issues, they are all copied to the new project.
2.) Create a project and clone the issues into this new project
I would recommend using issues with subtasks, because it is easier to clone them (less mouseclicks ) E.g. we have Testcases with many Tests as childs and it is easie to re-use them in another project or for a new software version.
