Gerrit connection from Jira
Athanasios Bladis October 13, 2014
Hello Atlassian Team,
i want to connect my JIRA Instance with gerrit. I alreade have buy the Gerrit Plugin and i dont know which rsa key is needed to connect JIRA with Gerrit
Athanasios Bladis October 14, 2014
HEllo,
i allready have installed the gerrit plugin and i dont know, which rsa key is needed. The rsa from Gerrit server or from jira?
BR
Athanasios Bladis
BMW Group
Ramiro P
October 16, 2014
It should be the rsa from Gerrit.
Ramiro P
October 14, 2014
Hi, this doc have a Getting Started section you can check: https://github.com/MeetMe/jira-gerrit-plugin/blob/master/README.md
In the other hand, did you payed for this plugin? because it's free of charge...
https://marketplace.atlassian.com/plugins/com.meetme.plugins.jira.gerrit-plugin
