Gerrit connection from Jira
Athanasios Bladis October 13, 2014
Hello Atlassian Team,
i want to connect my JIRA Instance with gerrit. I alreade have buy the Gerrit Plugin and i dont know which rsa key is needed to connect JIRA with Gerrit
Athanasios Bladis October 14, 2014
HEllo,
i allready have installed the gerrit plugin and i dont know, which rsa key is needed. The rsa from Gerrit server or from jira?
BR
Athanasios Bladis
BMW Group
Ramiro Pointis
October 16, 2014
It should be the rsa from Gerrit.
Ramiro Pointis
October 14, 2014
Hi, this doc have a Getting Started section you can check: https://github.com/MeetMe/jira-gerrit-plugin/blob/master/README.md
In the other hand, did you payed for this plugin? because it's free of charge...
https://marketplace.atlassian.com/plugins/com.meetme.plugins.jira.gerrit-plugin
