How can I get the Issue URL from post function?
Is there a way to retrieve this information?
Hi Chiara
We have the baseURL property that we provide in the binding of the script. This means that you can create a variable to show the URL using the issue key. Example code below will do this and then log it out:
def issueURL = baseUrl + '/browse/' + issue.key
logger.info(issueURL.toString())
Hope this will helps.
Kind Regards
Kate
