Get all issue status transitions and their respective Issuenum
Benjamin chee_guoee April 10, 2019
Hey community,
I refer to this amazing post
https://confluence.atlassian.com/jirakb/how-to-list-all-the-issue-status-transitions-from-database-in-jira-747832179.html
It has helped me get the issue transitions i needed.
Now I want to get the issue number of these issue transitions.
Can someone tell me which table to join to and on what.
Thank you very much!
Antoine Berry
Hi @Benjamin chee_guoee ,
Please try this :
SELECT
CONCAT(project.pkey, '-', jiraissue.issuenum) as issuenum,
changeitem.oldstring as oldstatus,
changeitem.newstring as newstatus,
changegroup.author as author,
changegroup.created as created
FROM changeitem
JOIN changegroup ON changeitem.groupid=changegroup.id
JOIN jiraissue ON jiraissue.ID = changegroup.issueid
JOIN project ON project.ID = jiraissue.PROJECT
WHERE changeitem.field='status'
Antoine
Antoine Berry
Did that help ?
Antoine
Benjamin chee_guoee April 17, 2019
Hi Antoine, yes it worked! Thank you! (:
Like Antoine Berry likes this
John Funk
Hi Benjamin - Welcome to the Community!
If you are looking for the ID of the transition itself (and not really an issue id/key) then you can find that by editing the workflow, then click on Text to see the full listing of all transitions and find the appropriate ID for it.
Hey John,
I will try this out!
Thank you!
